| Home > Help Needed / General Tech Chat > Traction | |||||||
![]() 537 Posts Member #: 8926 Post Whore Sheffield |
15th Jan, 2015 at 11:28:25am
Need a some advice please guys
15th Jan, 2015 at 11:34:21am
LSD would be a good start.
15th Jan, 2015 at 11:38:41am
Am I right in saying you have Sports Pack arches and 10's that fill them?
15th Jan, 2015 at 11:44:48am
Yeah i have sportspack on at the moment but they will hopefully be going when i replace my front end sometime this year.
15th Jan, 2015 at 11:52:06am
You can pop over and swap them over and back if you want. If something is worth doing, it's worth doing half of. |
15th Jan, 2015 at 11:55:47am
I expect the answer will be to fit a LSD, but worth checking the condition of the tyres first? How old is the rubber? If you rotate the wheels off the ground, do the tyes have any noticeable flat spots from sitting in the same spot?
Edited by PhilR on 15th Jan, 2015. |
15th Jan, 2015 at 12:13:06pm
yoko's have been know for batches to require a lot of heat to get them working (old stock) check the date on the tyres and what pressure do you run?
15th Jan, 2015 at 12:17:15pm
Worth a look at tyre pressure. If mine are too high I end up with zero grip. In the 13's at last!.. Just |
15th Jan, 2015 at 12:33:55pm
A big thing to consider is the roads are crazily slippy right now and have been for a good few months. !! |
15th Jan, 2015 at 12:50:30pm
I will check the tyres when i get home, pretty sure they are over 2 years old now but has decent tred left on them. Whats the average tyre pressure you guys run?
Edited by Nick warwick on 15th Jan, 2015. |
15th Jan, 2015 at 04:55:48pm
Do you have adjustable shocks? If they are set to hard that can cause traction problems. If they can be adjusted try them on full soft then on full hard and see what the differeance is. That said front to back firmness/softness can have a effect too.
http://www.twin-turbo.co.uk
3596 Posts Member #: 655 Post Whore Northern Ireland |
15th Jan, 2015 at 06:38:22pm
On 15th Jan, 2015 Nick warwick said:
Need a some advice please guys I seem to struggle to keep traction while coming on boost, only running 10psi. Running A032 tyres and have the suspension set up correctly courtesy of Wil (again a massive thank you for that) and also corner weights set up. I have done the different driving styles feathering the throttle to keep a nice smooth boost rise while this works i still would like to be able to use the power without it being wasted in wheel spin. Even when i am at 60-70 and i put my foot down i get traction problems. What would be my best options to improve this? I was thinking either larger wheels as i am running 10's at the moment although i like 10's for the looks or an LSD. My current diff is whatever was in a standard 1993 mayfair so not sure what the ratio is. Thanks Nick When you say traction problems...do you mean a little slip, or full on tyre smoking action ? Breaking traction with only 10psi at 70mph....seems a little odd ? In which gear, on a roll, or are you provoking it ? Taller gearing generally helps, so it would be good to know actual gearing. So in that respect a taller diff, or as you suggest taller tyres can often be a huge help Depending on base wastegate pressure you could also look into boost control, and ramp boost in with rpm or speed etc. That should smooth power delivery and massively help with traction ( even if it may not always feel as good to the driver ) 9.85 @ 145mph
15th Jan, 2015 at 06:59:01pm
Where are you driving? if its on the roads then suck it up till the summer comes, also I had more traction with good road tyres (dunlops, continentals, pirelli however were shit) than I had with trackday tyres Tried A048s and Kumho V70s. Youll need a 13" wheel though to get modern road tyres. Edited by evolotion on 15th Jan, 2015. turbo 16v k-series 11.9@118.9 :)
15th Jan, 2015 at 08:27:09pm
Traction issues? Join the club Yes i moved to the darkside |
15th Jan, 2015 at 08:38:50pm
i would with those 10s if your sticking with them up the diff ratio to 2.95:1
16th Jan, 2015 at 09:13:43am
On 15th Jan, 2015 Ben H said:
Do you have adjustable shocks? If they are set to hard that can cause traction problems. If they can be adjusted try them on full soft then on full hard and see what the differeance is. That said front to back firmness/softness can have a effect too. I would say tyre pressures are a better starting point though. Yeah i have Gaz adjustables which from memory are set to fairly hard but i will check the tyre pressures before adjusting anything else. On 15th Jan, 2015 stevieturbo said:
When you say traction problems...do you mean a little slip, or full on tyre smoking action ? Breaking traction with only 10psi at 70mph....seems a little odd ? In which gear, on a roll, or are you provoking it ? Taller gearing generally helps, so it would be good to know actual gearing. So in that respect a taller diff, or as you suggest taller tyres can often be a huge help Depending on base wastegate pressure you could also look into boost control, and ramp boost in with rpm or speed etc. That should smooth power delivery and massively help with traction ( even if it may not always feel as good to the driver ) It's by no means smoking the tyres up but it slips badly even in the dry hot weather we had last summer which is the main time i used it. It can slip/loose traction in all gears without planting a lead foot. As for my current diff ratio can i work it out with just knowing how many teeth the diff has? or will i need the pinion number too? never worked out a diff ratio. If this is the case i will get the engine out sometime Cheers |
16th Jan, 2015 at 10:07:22am
Out of interest, what clutch are you running? |
16th Jan, 2015 at 10:35:03am
Hmmm not sure what my clutch ever was. It's from the engine i got of Kappashitface |
16th Jan, 2015 at 10:43:38am
there is a gear calculator on 'guessworks' site that you can play with to give you a rough idea of the final drive fitted.
16th Jan, 2015 at 12:35:19pm
Well 4th is 1:1, so what speed are you doing at say 4000rpm in 4th ?
16th Jan, 2015 at 01:08:58pm
i would say around 60-70 of the top of my head.
16th Jan, 2015 at 01:31:54pm
18/62 gives 3.44 <--- probably this?
16th Jan, 2015 at 06:56:48pm
On 16th Jan, 2015 Nick warwick said:
i would say around 60-70 of the top of my head. 165/70/10 Just had a quick count on a photo of my diff when i had it out, has 62 teeth and from memory was from a 1993 carb 1275cc Mayfair That's a big range. Stick a 2.95 or 3.1 into it. The only thing I can say for sure without an accurate speed, is that you definitely dont have either of those two diffs. 3.44 would place you at approx 66 mph at 4000rpm 3.1 would place you at approx 72-73mph at 4000rpm 2.95 would place you at approx 77 mph at 4000rpm Assuming 1:1 drops. Or fit larger 12 or 13" tyres. 165/60x13's will lift you up to around 71mph at the current guessed 3.44 diff. A small jump but still a worthwhile one. 175/50x13 a more popular size really makes little difference as far as gearing is concerned 9.85 @ 145mph
![]() 330 Posts Member #: 9628 Senior Member |
16th Jan, 2015 at 07:06:37pm
+1 on tyre pressure mine have always been 28psi
Edited by coopdog on 16th Jan, 2015. |
16th Jan, 2015 at 07:38:32pm
Orrrr, you could just run more boost so power overcomes the traction problems Edited by Carlzilla on 16th Jan, 2015. On 26th Jan, 2012 Tom Fenton said:
