| Home > Help Needed / General Tech Chat > Wideband O2 Sensor | |||||||
19 Posts Member #: 10415 Member |
11th Feb, 2015 at 08:19:02pm
Evening chaps,
11th Feb, 2015 at 08:22:05pm
a lot of folks on here are using the AEM one with good results,
11th Feb, 2015 at 08:50:04pm
I've used a few Innovate stuff...and probably wouldnt buy again.
11th Feb, 2015 at 10:36:12pm
On 11th Feb, 2015 stevieturbo said:
I havent used the AEM...but rarely do you see a bad report. That depends where you look... They won't stop working and throw error codes like the Innovate but the value of the numbers they do display is another matter. |
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
12th Feb, 2015 at 11:01:20am
I've got the Innovate one fitted and it seems to be working just fine. Metric is for people who can't do fractions. |
12th Feb, 2015 at 12:52:47pm
I'm very happy with the AEM.
Edited by PhilR on 12th Feb, 2015. |
12th Feb, 2015 at 07:06:17pm
I havent used the AEM...but rarely do you see a bad report. That depends where you look... They won't stop working and throw error codes like the Innovate but the value of the numbers they do display is another matter. Could say the same about them all really. They all claim to be the most accurate, better, faster than everyone elses. All I know for sure...is Innovate eat sensors and are troublesome. As to which is currently best...havent a notion. But even one slightly off...is better than nothing at all as long as it's repeatable and reliable 9.85 @ 145mph
12th Feb, 2015 at 08:19:02pm
I havent used the AEM...but rarely do you see a bad report. That depends where you look... They won't stop working and throw error codes like the Innovate but the value of the numbers they do display is another matter. Could say the same about them all really. They all claim to be the most accurate, better, faster than everyone elses. All I know for sure...is Innovate eat sensors and are troublesome. As to which is currently best...havent a notion. But even one slightly off...is better than nothing at all as long as it's repeatable and reliable I agree with you that all controllers have received criticisms for one reason or another. And the Innovate is troublesome and fussy about sensors. It actually doesn't hurt the sensors but will refuse to work with them; use the sensor with another controller and it works fine. Alan To from 14point7 has demonstrated that more than once. The only thing that happens is that the sensor responds a bit slower than a brand new one but still fast enough to be used without issues (with the right controller). As for AEM, there has been many reports about inaccuracies and a mismatch between the analog output and the gauge display. There is no way to know which is valid (or if neither is valid) without lab testing with calibration gases. And some independent tests have not shown very good results. And I disagree that it's better to have number than to have nothing. If you do believe wrong numbers, you make decisions based on wrong data which can lead to catastrophic failures. Without data, you act accordingly (or you should) and err on the side of caution. So I can't really make an unconditional recommendation. I do know which one I would use but there are issues other than the quality of the measurement that would come into consideration. But I don't like or trust AEM and Innovate does have issues. |
12th Feb, 2015 at 08:24:36pm
Thanks for the replies chaps. So the AEM has issues, and the Innovate can be fussy with sensors. Is the datalogging of any use with the Innovate? Is there another unit that i should be looking at?
12th Feb, 2015 at 08:48:15pm
i have 2 AEM UEGO settups,
Edited by Brett on 12th Feb, 2015. Yes i moved to the darkside |
12th Feb, 2015 at 10:36:47pm
On 12th Feb, 2015 m30 said:
So the AEM has issues, and the Innovate can be fussy with sensors. ... Is there another unit that i should be looking at? There are plenty of us with 1st hand experience, running each with no show stopping complaints. This isn't a major issue at all, but I found the AEM a bit dim in very strong sunlight. The bezel is also quite deep, so depending on where you mount it, some of the display could be obscured by the bezel. Here's another AEM to look at below. This would have solved the 2 issues I had, and IMO looks far tidier than both the other AEM and Innovate. Carlzilla showed me this one - Looked great with the Minis classic gauges. AEM 30-5130
EDIT: removed ebay link Edited by PhilR on 15th Feb, 2015. |
13th Feb, 2015 at 01:00:15am
I certainly wouldnt trust Innovate's analogue outputs.
13th Feb, 2015 at 10:06:32am
I've mentioned this in another thread but I have had an Innovate fail and so has Graham (he sent his to me to double check as we both use the same ECU setup that reads their digital data, not the usual analogue).
13th Feb, 2015 at 11:59:04am
On 13th Feb, 2015 Rod S said:
One final point, whilst every man and his dog are selling Innovates and AEMs on eBay, the likes of TechEdge and 14point7 don't appear (well, not that I've seen) so you have to buy direct or from an authorised agent. DO NOT BUY a 14Point7 controller until there's a reseller in UK / Europe. I bought mine straight from 14Point7 in Canada and the process was unnecessarily painful. Edited by PhilR on 13th Feb, 2015. |
![]() 112 Posts Member #: 10125 Advanced Member Zoetermeer, The Netherlands |
13th Feb, 2015 at 07:54:48pm
For a couple of years I've used two sets of Innovate. Without any problems. One set is permanently fitted in my mini, making the normal road my roller road when used in combination with a Gtech Pro.
14th Feb, 2015 at 12:49:30am
Dont know about the technicalities but the A35 has used an AEM for the last 5 years or so and I have relied on the readings to run up to 17psi without any apparent problems,
14th Feb, 2015 at 10:28:55am
On 12th Feb, 2015 jbelanger said:
As for AEM, there has been many reports about inaccuracies and a mismatch between the analog output and the gauge display. There is no way to know which is valid (or if neither is valid) without lab testing with calibration gases. And some independent tests have not shown very good results. Do you have a link to any of these tests? Ive had a google but couldnt find much. On 28th Aug, 2011 Kean said:
14th Feb, 2015 at 10:28:57am
14th Feb, 2015 at 10:35:16am
https://www.youtube.com/watch?v=-H4ceCOMXHY On 11th Feb, 2015 robert said:
14th Feb, 2015 at 10:56:46am
A quick google shows it's been mentioned on many car forums.
Edited by Rod S on 14th Feb, 2015. Schrödinger's cat - so which one am I ??? |
14th Feb, 2015 at 12:44:12pm
To be clear, my AEM was not inaccurate. The quoted 5V calibration data was miles out, but was easy to spot and correct. You shouldn't rely on any other sensor output without checking the calibration.
14th Feb, 2015 at 01:46:12pm
On 14th Feb, 2015 PhilR said:
The quoted 5V calibration data was miles out, but was easy to spot and correct. You shouldn't rely on any other sensor output without checking the calibration. That is exactly what I was referring to, but how do you know your new calibration is correct ? Do you have some calibration gas or are you just assuming the gauge is right and the 0-5V calibration wrong ? Plenty of others have also seen the calibration data mismatch but I can't see anyone who has actually proven which is right (if either). The thing to bear in mind is, then that what I'm referring to is the reports of the 0-5V output giving a different value in an EMS/ECU display or datalog compared to the actual AEM dashboard gauge. If people are using AEM's own figures for 0-5V vs AFR to calibrate their ECU and getting different readings something is wrong. The usual problem is people haven't done their wiring very well and are getting a ground offset. And probably more than half the people complaining fall into that category. But when I see people like James Murray on the MS-E forum (he's one of the MS-E code writers and builds/repairs ECUs) state that he has seen it himself, he's not the kind of person I'd expect to have dodgy wiring. The real point is the majority on this forum use an SU so won't even use the 0-5V analogue output so will just assume the gauge is correct. But for those who have some sort of EMS/ECU - the majority of the car tuning world – and have seen this difference (and don't have dodgy wiring), then which is correct, the gauge, or the 0-5V, or neither ? The majority of aftermarket ECUs only provide 0-5V inputs for widebands, rather than digital. There are probably a few exceptions where the manufacturer of the ECU and the wideband controller are the same but if you take SC as an example (as a few people on here use them) I see no reference to digital inputs, just 0-5V. Those who use an ECU will either then just use the datalog to assist with tuning or may (if the ECU allows) set up some form of closed loop control where the ECU adjusts the fuelling to try and correct the AFRs from what the base table is setting. Those kind of people would like the 0-5V reading to be correct. Like I said before, I have no experience of the AEM but, after certain comments, I thought it worth researching. But I have no axe to grind, I chose to swap to an all digital setup (because I have a hardware combo that can accept and display the true digital values) so my dash gauges read exactly the same as the ECU is seeing, ground offset, wiring or 0-5V calibration just becomes irrelevant. I also use the factory gas calibration setting of the individual sensors (there is a laser etched resistor in the plug that is set at the factory on a test gas close to the exhaust combination of a running engine) rather than the “free air” calibration that so many aftermarket widebands rely on. Apparently some makes can't even use the factory value. But I can't see the point of calibrating at off scale lean values rather than running values. Anyway, just my thoughts. Schrödinger's cat - so which one am I ??? |
14th Feb, 2015 at 04:15:16pm
The controller reads the sensor output, calculates the AFR value and displays it straight onto the digital display (A). From that same AFR value, the controller then generates a 0-5V signal (B).
Edited by PhilR on 14th Feb, 2015. |
14th Feb, 2015 at 05:04:39pm
http://www.fordmuscle.com/archives/2007/06...otout/index.php
Edited by robert on 14th Feb, 2015. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
14th Feb, 2015 at 05:37:10pm
Robert, I have to pay $19.95 to see the results and I don't think the ones I use are in there.
