| Home > Good Garages & Parts Suppliers > AC Dodd | |||||||
![]() 553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
21st Nov, 2016 at 07:29:02pm
My first RTS was not right after sending it for machining and balancing etc to people not too familiar with minis. I decided to start over and using new parts sent all the bits to AC Dodd who agreed to machine and balance the assembly.
16th Dec, 2016 at 07:34:56pm
Don't let him balance your rods... On 13th Jul, 2012 Ben H said:
167 Posts Member #: 11091 Advanced Member |
16th Dec, 2016 at 10:27:25pm
is this a bad review of minispares too?
Edited by Will on 16th Dec, 2016. |
17th Dec, 2016 at 01:03:17pm
A few people have said the Minispares billet flywheel distorts once the ring gear is fitted to it. Mine was like that. AC said all the ones sent to him are like that |
17th Dec, 2016 at 01:04:36pm
On 16th Dec, 2016 Will said:
is this a bad review of minispares too? about to build an RTS and wondering if you could post a breakdown of the costs of having AC Dodd build it? (Or can PM, would help alot!) |
10 Posts Member #: 11490 Member |
22nd Dec, 2016 at 07:55:38am
Thanks for the plug!
22nd Dec, 2016 at 08:38:58pm
On 22nd Dec, 2016 ACDodd said:
Thanks for the plug! Please explain Vegard? Ac I'll happily explain. Previous you said that when balancing rods, you weighed the two parts separately and as long as all the caps weighed the same and all the beams were the same, they were balanced. I said no, and you said that this had always worked for you. That's why. On 13th Jul, 2012 Ben H said:
23rd Dec, 2016 at 01:26:33pm
Yes I call I a crude balance. Still do it this way. This is explained to customers before the work commences.
23rd Dec, 2016 at 07:37:27pm
Crude balance, as in "NOT balanced"?
24th Dec, 2016 at 09:32:42am
Original rod sets are 2 to 3 grams variation. This is reduced to within 0.1 gram. This Is considerably better than stock. Its a similar argument to those who.also say you cannot statically balance a flywheel and clutch. Clearly you van if you try it (as I have for 25 years). Not saying tho mehod os the correct way to do it either but it does improve things a great deal. Nothing is perfect, the work simply moves the components much closer to optimum.
24th Dec, 2016 at 10:04:38am
Also to this is my hobby and simply do not do the volume to warrant an expensive jig. My work is focused on road engines that rarely see over 6.5k rpm this method works perfectly well in the window I operate in.
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
24th Dec, 2016 at 11:30:17am
I did a set of rods in this manner for Tubbs, and can feel no difference between her engine and the one in Betty which is bog-standard in terms of smoothness.
Metric is for people who can't do fractions. |
24th Dec, 2016 at 11:45:50am
Good point and I do have an answer. In the last 4 weeks I was discussing this with Neil Slark and he was able to show me an original factory weight table for A+ conrods which were graded into colour coded sets. The colours painted on each rod. They were then selected by a matched colour set. These sets were 2 grams apart. There was not end to end balance process. Simply weight alone.
24th Dec, 2016 at 12:58:14pm
Interesting.
24th Dec, 2016 at 01:32:45pm
Big ends are machined after the caps are in place.
24th Dec, 2016 at 08:54:23pm
Welcome to the forum AC. There is some good Turbo info on here. |
24th Dec, 2016 at 09:49:49pm
I'll be honest, my rods are only balanced like AC described. If I was in the 7.5k+ territory, I'd do it differently... On 17th Nov, 2014 Tom Fenton said:
24th Dec, 2016 at 10:30:48pm
Thanks for that turbodave, I know other engine builders do the same too.
25th Dec, 2016 at 12:20:11am
Well let's not fool ourselves, the best way is to balance end-to-end.
Edited by turbodave16v on 25th Dec, 2016. On 17th Nov, 2014 Tom Fenton said:
25th Dec, 2016 at 12:23:23am
Anyway, back to this MS billet flywheel buckling; is that the same as the MED one? Edited by turbodave16v on 25th Dec, 2016. On 17th Nov, 2014 Tom Fenton said:
25th Dec, 2016 at 09:17:46am
I had the MED Verto billet flywheel, the one they were selling a couple of years ago and my machinist said the pedestals were all different heights. The ring gear was also wonky. I would not buy one of these from MED again. Different flywheel to the one i recently bought from minispares Edited by dazibee on 25th Dec, 2016. |
25th Dec, 2016 at 12:49:23pm
Not tried the MED one. However thin section flywheels with offset ring gear will all warp when the ring gear is fitted. They need to be machined after the ring gear is fitted to ensure flatness.
25th Dec, 2016 at 03:28:24pm
I just looked at the MED site; definitely different to the Minispares version being they are machined through on the lightening pockets... The interesting thing about the MED is they use m6 screws to Dutch / scotch (whatever your preference in lingo) the ring gear to the flywheel. This likely means very little intereference fit, which means little warpage.
25th Dec, 2016 at 04:41:58pm
MED modified their verto flywheel a few years ago to try and stop this problem.. Not sure how well it worked. I have an alloy one which lots of people said wouldn't work but it appears fine so far. |
25th Dec, 2016 at 07:01:46pm
Agreed, if the interference fit is reduced then the warp should refuce/dissappear. That MED one looks like it could be just the ticket. You would need to check one and see what gives. In any case it still may not change the need to machine, as you will still need to check that the horn height is correct for the diaphragm and friction disc combination you are using.
