| Home > Show Us Yours! > 1978 Van turbo build | |||||||
60 Posts Member #: 11964 Advanced Member Lindlar |
27th Oct, 2020 at 11:56:13am
Edited by Ralf on 27th Oct, 2020. |
28th Oct, 2020 at 03:59:55pm
Vans are great, but you gotta lot of work ahead of you ! 9.85 @ 145mph
29th Oct, 2020 at 11:59:46am
yes, it's a big metal puzzle.
29th Oct, 2020 at 05:24:53pm
I didn't know there was ever an MG Metro van ???
Edited by Rod S on 29th Oct, 2020. Schrödinger's cat - so which one am I ??? |
30th Oct, 2020 at 11:16:24am
ah, ok. I checked the Metro engine number again in the internet.
30th Oct, 2020 at 01:37:29pm
On 30th Oct, 2020 Ralf said:
You give me headache regarding the van fuel tank. I had a hard time to find a good one. Is it really so bad that I can't use it? No, of course not - you just have to be aware of the issues from it being so low down and wide and the way the fuel will slosh around under cornering. You are hardly building a turbo to drive it slowly around corners...... There are quite a few threads on this forum as to how people have got over the basic issue with some simple solutions and some who get all excited with lift pumps, swirl pots and many more exotic solutions. Just do a search to see how different people have addressed the issue. What you do not want is the pump to suddenly lose suction on a fast corner and send your AFRs super lean. Schrödinger's cat - so which one am I ??? |
31st Oct, 2020 at 05:19:02pm
You give me headache regarding the van fuel tank. I had a hard time to find a good one. Is it really so bad that I can't use it? No, of course not - you just have to be aware of the issues from it being so low down and wide and the way the fuel will slosh around under cornering. You are hardly building a turbo to drive it slowly around corners...... There are quite a few threads on this forum as to how people have got over the basic issue with some simple solutions and some who get all excited with lift pumps, swirl pots and many more exotic solutions. Just do a search to see how different people have addressed the issue. What you do not want is the pump to suddenly lose suction on a fast corner and send your AFRs super lean. I've done this recently as I have a clubman estate. Same fuel tank. I went with a swirl pot and lift pump and high pressure pump. The only reason I did this was because I couldn't find a definitive answer on if I needed one or not. Some say you do, some say you don't etc. So i went with after the advice of Gavin Wilkinson on the facebook group. I've mounted the lift pump on a plate that attaches to the rear subframe using the rubber bobbins. Then the swirl pot is in the boot mounted to the plate that is pop rivetted in around the wheel arches. Then I have a HP pump on the rear subframe. |
432 Posts Member #: 7856 Senior Member Essex |
3rd Nov, 2020 at 09:08:50am
Hazpalmer, have you got a link / build thread which shows your install at all? |
51 Posts Member #: 10080 Advanced Member Holland, Eindhoven |
3rd Nov, 2020 at 08:07:10pm
I did the same. Hp-pump under the car mounted on the subframe and that was enough to do the job. Make a return hose on the tank. |
4th Nov, 2020 at 08:57:46am
good informations thanks a lot.
Edited by Ralf on 4th Nov, 2020. |
25th Nov, 2020 at 11:20:25am
small update.
25th Nov, 2020 at 03:53:12pm
If your machine shop really returned your cylinder head in the condition shown in the photos I would have to question their competence.
![]() 428 Posts Member #: 10128 Senior Member Dorset |
25th Nov, 2020 at 06:24:02pm
On 29th Oct, 2020 Rod S said:
Cam - if the doner is a genuine MG Metro, NORMALLY ASPIRATED, that cam is a good start for a turbo. The MG Metro Turbo cam is not.... it's just a plain 1275 cam..... the normally aspirated MG Metro had an improved cam. I did not know that, thanks for the info Rod. Good luck with the build Ralf. That head definitely needs a little more love. |
25th Nov, 2020 at 07:09:56pm
yes sure, but no problem. I will do the cleaning.
264 Posts Member #: 11029 Senior Member Crewe |
26th Nov, 2020 at 07:02:03pm
On 3rd Nov, 2020 Bill said:
I did the same. Hp-pump under the car mounted on the subframe and that was enough to do the job. Make a return hose on the tank. Ive gone a little mad lift pump and hp in the spare wheel well on my estate and a swirl pot set into the wheel well with a bit sticking above or at least thats how its mocked up atm Outside the box |
4th Dec, 2020 at 04:21:17pm
small update.
15th Mar, 2021 at 06:27:39pm
after a slight delivery delay, some parts have arrived.
16th Mar, 2021 at 09:16:06am
On 15th Mar, 2021 Ralf said:
![]() Good progress. But I hate to be the one to tell you, it won't work that way up...
16th Mar, 2021 at 10:03:44am
16th Mar, 2021 at 11:24:29am
the struggle waiting for parts to arrive! Looks good, how does the CSI dizzy work? |
16th Mar, 2021 at 12:08:59pm
I'm not an ignition expert. that's why i bought the csi pro ignition with usb connection.
24th Mar, 2021 at 09:13:51pm
Fortunately, after a few weeks of delivery I received my MLS Cometic cylinderhead gasket.
28th May, 2025 at 03:00:56pm
so, long time not here.
Edited by Ralf on 28th May, 2025. |
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
29th May, 2025 at 07:47:55am
looking good! 'Where does the engine go?' |
339 Posts Member #: 399 Senior Member Austria |
30th May, 2025 at 10:17:21am
Yeah baby! Very cool!
great, thanks.
