| Home > Help Needed / General Tech Chat > Rockers 1.5:1 or STD | |||||||
![]() 243 Posts Member #: 89 Senior Member Sydney Australia |
1st Nov, 2005 at 03:42:41am
Hi all, juts getting your thoughts here, i have just placed my order for the Avonbar Phase 3 Cam kit, would you prefer to use the STd rockers with this cam or continue with my 1.5:1 rockers? 179hp on 12psi 1293cc of pure A series
1st Nov, 2005 at 06:54:14am
stick with standard as they give slightly more torque at the bottom with out losing hardley any at the top. always looking for them bigger bunches of bannanas |
1st Nov, 2005 at 10:23:25am
The ph3 is a very spikey cam......
1st Nov, 2005 at 10:55:15am
I ran 1.5s on a Ph2, totally useless. Could hardly get the car off the line.
1st Nov, 2005 at 12:34:59pm
JF- were you running 1.5's with it aswell? On 17th Nov, 2014 Tom Fenton said:
1st Nov, 2005 at 01:13:02pm
I run 1.5's with the MED cam - which is the same as the phase 2 I belive.
1st Nov, 2005 at 01:49:56pm
I run 1,5s on a Ph2, and find it not much worse than what it was like on 1,3s.. Getting off the line is dead easy. On 13th Jul, 2012 Ben H said:
1st Nov, 2005 at 02:15:46pm
IMHO forget the ph 3 cam unless you are totally tracking the car ALL the time.
1171 Posts Member #: 107 Post Whore Sunny Sussex |
1st Nov, 2005 at 03:47:16pm
seems to be an area for discussion, there was a thread a while ago about this but was never really 'concluded', i've got a ph2 and not sure wether to run std 1.3's or get a 1.5
1st Nov, 2005 at 05:24:14pm
i'm running a ph2 and 1.5's although it hasnt turned a pulley yet |
1st Nov, 2005 at 06:10:09pm
Yes i run 1.5's, tbh i have never tried 1.3's. the engine on boost a 3200rpm.
1st Nov, 2005 at 07:27:07pm
I have run the phase 2 with 1.5 rockers. Only a slight hint of "caminess" on idle, totally drivable with a good power spread. This cam is great for road motor, power from low down, and pulls nicely up to 6 - 6,500 or so. This engine had a moderatley modified head and 8.5-1 compression, running a T3 Turbo.
1st Nov, 2005 at 10:23:06pm
hhmm very interesting replies there thanks to all of you.
1st Nov, 2005 at 10:28:45pm
2nd Nov, 2005 at 04:55:23pm
You think the Kent 500 (mgMetro profile) was lumpy? And you're going for a ph3????
2nd Nov, 2005 at 05:29:38pm
red the phase 2
Edited by BENROSS on 2nd Nov, 2005.
2nd Nov, 2005 at 06:44:34pm
does any one no the overlap period for a p2 and p3 always looking for them bigger bunches of bannanas |
2nd Nov, 2005 at 08:39:56pm
here you go
3rd Nov, 2005 at 02:32:47pm
What was the discussion regarding the differences between the 'supplied' and 'actual' timing figures... I'm sure i recall this recently??? On 17th Nov, 2014 Tom Fenton said:
3rd Nov, 2005 at 04:38:11pm
buy the looks of that cam i guess you were using 1.5 rockers always looking for them bigger bunches of bannanas |
3rd Nov, 2005 at 10:32:08pm
yes i was using the mini spares 1.5:1 rockers
Edited by RED850 on 4th Nov, 2005. 179hp on 12psi 1293cc of pure A series
4th Nov, 2005 at 09:06:45am
thats another reason i dont like them , they have a tendancy to chew cams and followers up for breakfast.
4th Nov, 2005 at 12:59:54pm
This only happens if you don't change valve spring pressure accordingly. The reason why the 1,5 chew valvatraisn is because people use the same springs as they did on the 1,3s. This in addition to the "harder springs is better pub factor" On 13th Jul, 2012 Ben H said:
17th Jan, 2006 at 12:36:33pm
how do u work out which springs to use with what cam? for example i have the ph2 fitted, unsure what springs are on the MED turbo head i have tho. Still undecided on whether to go 1.3 or 1.5 too. Edited by Mike on 17th Jan, 2006.
133 Posts Member #: 703 Advanced Member Plymouth, On the floating skip known as HMS Albion |
17th Jan, 2006 at 04:48:15pm
In a previous post on this subject didnt avonbar strongly recommend using 1.3's with a phase 2? Whats going to break next!?
