| Home > Help Needed / General Tech Chat > dash pot oil low? | |||||||
133 Posts Member #: 703 Advanced Member Plymouth, On the floating skip known as HMS Albion |
17th Dec, 2005 at 11:04:46am
Hi im running a 1293 with a T2 turbo and phase 2 cam. Last night after a couple of hours driving my car seemed to die out if i opened the throttle more than say half way, it was as if it was sucking in to much air and leaning out. After stopping at service station and fiddling I topped up the dashpot oil with 20w50 and set off the car was perfect again. Then about 50 miles later same thing happened again so once again topped up the oil and it was cured.
Whats going to break next!?
17th Dec, 2005 at 04:37:42pm
the probable cause will be worn daspot plunger
19th Dec, 2005 at 07:42:41pm
so i can use any two dashpot springs wound together?
19th Dec, 2005 at 07:44:03pm
How much are you topping it up to? It does not need to be all the way to the top, just to the top of the piston rod which is visible with the cap unscrewed.
19th Dec, 2005 at 08:07:34pm
ah right i was just topping up all the way which seemed to cure the problem until i start going full throttle which shortly after it will re-occur.
19th Dec, 2005 at 08:10:47pm
Is this something that has just started in cold weather? Could it be carb icing? If you are driving and it dies, if you stop for 5 mins and then set off again without touching dashpot oil level is it then OK?
19th Dec, 2005 at 08:21:58pm
Well i haven't been running this engine long so i couldn't comment on the cold weather. It only dies out while the throttle is held open it will run fine at lower revs. Ill try stopping for 5 mins tomorrow when no doubt it happens again! Whats going to break next!?
19th Dec, 2005 at 09:37:57pm
my above thread would be probable cause
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
20th Dec, 2005 at 05:49:14pm
cant you smell burning oil or anything? sounds like its just leaking out, but i have no doupt you would smell it burning on the turbo...
Edited by pot_dan on 20th Dec, 2005. |
20th Dec, 2005 at 07:28:42pm
i cant smell any oil burning. I have put a different piston plunger in but haven't been out for a run in it yet as im working on the brakes. It seems to leak away very rapidly, does the dashpot have a seal apart from the fibre washer on the top? Whats going to break next!?
20th Dec, 2005 at 11:26:21pm
i am unsure about the seal, i know you can take the dashpot off with the 3 screws but i havent rebuilt a carb before so dont know were the oil is held in, maybee if you take it to bits urself it will reveal itsself:)
21st Dec, 2005 at 07:43:48am
Sounds as it's either leaning out or flooding, doesn't it? On 13th Jul, 2012 Ben H said:
21st Dec, 2005 at 02:00:54pm
thats what i thought, I just changed the dashpot plunger went out in it and after overtaking one car at full throttle in third as soon as i shifted to fourth it started. Pulled over and the dashpot appeared to have a tiny amount of oil at the bottom. Going to take the top now have a look try a different spring
Edited by slim_shadyuk on 21st Dec, 2005. Whats going to break next!?
21st Dec, 2005 at 03:09:58pm
update: just took the dashpot off and would i be right in thinking the turbo HIF 44 has an o-ring seal? there was a seal fitted but it was too big and not seated properly looks like one off a float bowl!
21st Dec, 2005 at 03:11:34pm
right slim have you tried the T peice trick?
21st Dec, 2005 at 03:12:43pm
oh! dont for get to fit a stronger dash pot spring
21st Dec, 2005 at 03:21:30pm
ithat was already in place i actually just took the t-piece off to see if there was any difference!
21st Dec, 2005 at 04:23:56pm
I suspect that the dashpot oil thing is a red herring that is throwing you off the real problem.
21st Dec, 2005 at 06:28:36pm
i agree Tom i tried two dashpot springs and no difference i guess the time taken to fill up the dashpot was just as good as pulling over for 5 mins like you suggested!
22nd Dec, 2005 at 07:39:12am
3,5 bar??? That is 50psi! Sure you don't mean 3,5 Psi which is SHOULD be?
22nd Dec, 2005 at 01:52:35pm
Yes i meant 3.5 psi.
22nd Dec, 2005 at 03:06:15pm
Topping the oil up too far can cause it to suck it out very quickly. try putting less in. |
28th Dec, 2005 at 03:28:07pm
ok i've now checked the fuel pressure and at idle is about 0.2 bar peaking at 0.5 bar at 6.000 rpm.
28th Dec, 2005 at 04:46:26pm
0.1bar boost? That is 1.4 psi. I can fart harder than 1.4psi.
28th Dec, 2005 at 05:26:56pm
boost hose off, fooked over boost valve, split in boost hose, actuator arm off etc etc |
