| Home > General Chat > I fitted an oil cooler today!!!!!!! | |||||||
19th Feb, 2004 at 06:49:29pm
Well I though I better as I have plans to do a few track days and top speed runs this year. Best 1/4 mile 13.2 seconds @116 mph
![]() 323 Posts Member #: 41 Senior Member |
19th Feb, 2004 at 09:07:19pm
whats your thermostat set at do you know? ive just got a 13 row i think, might be 10, put in without a stat at the moment, its amazing how much it cools the oil, hold the inlet and its hot, hold the outlet pipe and its alot cooler. probably coz mine is right behind the grille, no obstructions A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
20th Feb, 2004 at 12:08:19am
I think its 74 degrees, which isn't reallt hot enough but it's better than nothing, won't make any difference on the cooling at low engine speeds as it bearly makes 70 degrees.
20th Feb, 2004 at 09:19:08am
ive got an oil temp gauge ready to go in, just need to get some sort of adaptor made up for the sender unit. when i put it in over the next few weeks i'll run the car with and without the cooler and see what kind of difference it makes and let you know A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
20th Feb, 2004 at 09:22:57am
I've got some kit you can borrow to find out if you want MW....
AlexF |
20th Feb, 2004 at 06:25:21pm
1310turbo sounds good keep me posted.
263 Posts Member #: 115 Senior Member Austria, near Vienna |
22nd Feb, 2004 at 09:08:48am
Hi Folks!
Bimmer Twinky headed and turboed A-Series:
22nd Feb, 2004 at 09:14:07am
thanx for the tip harry, welcome to the site! A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
10 Posts Member #: 156 |
23rd Feb, 2004 at 02:11:23pm
. Edited by AlexF2003 on 23rd Feb, 2004. please ignore my post, I tell lies!!! |
23rd Feb, 2004 at 08:30:22pm
What did his post say before it was edited? |
23rd Feb, 2004 at 09:11:59pm
Nothing anyone will miss AlexF |
23rd Feb, 2004 at 09:42:58pm
I'm curious
24th Feb, 2004 at 09:29:45am
fab, you need to be a moderator to change other peoples posts On 15th May, 2009 TurboDave said:
24th Feb, 2004 at 05:32:12pm
some people eh? On 21st Jan, 2011 fastcarl said:
24th Feb, 2004 at 07:10:01pm
The post I edited was completely pointless.. had no benifit for this post and bordered on agressive... so I edited it.
AlexF |
24 Posts Member #: 183 Member |
25th Feb, 2004 at 01:35:31pm
what did it say i am new here an i dont like the sound of this 1275mk1miniturbo it sounds like a right to$$er if u know what i mean |
25th Feb, 2004 at 03:48:21pm
I see Admin has changed his sig aswell...
25th Feb, 2004 at 04:11:06pm
I can't remember now...
AlexF |
25th Feb, 2004 at 09:26:08pm
Went for a drive with the new cooler, well after a long hard run with lots of boost the oil got to 80 degrees only. so at least i can now drive it hard for miles and miles now with out the odd short oil cool slow down breaks.
26th Feb, 2004 at 07:20:48am
what do these oil thermostat thingys cost matt? On 15th May, 2009 TurboDave said:
27th Feb, 2004 at 06:55:25pm
Not sure exactly mate but i think it's around ?15-20 for the thermostat and around ?14 ish for the temp take off. Best 1/4 mile 13.2 seconds @116 mph
28th Feb, 2004 at 06:44:10pm
really want to get my oil temp gauge in to see what effect my cooler has, dependant on that i will get a thermostat, although they sound like a good idea. and 80deg sounds very safe A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
29th Feb, 2004 at 11:05:11pm
yes mate it's very safe, if any thing it might be a shade to cool, but we all change our oils regularly i guess so it shouldn't matter. Best 1/4 mile 13.2 seconds @116 mph
1st Mar, 2004 at 12:57:46pm
More power if you keep it at about 100....
AlexF |
1st Mar, 2004 at 01:37:08pm
Miniwilliams.
