| Home > General Chat > je pistons | |||||||
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
29th Mar, 2006 at 10:45:44pm
I bought some +0.020 18cc JE pistons from minispeed and have just fitted two of them to the block. When i ordered them, they didnt tell me anything about fitting them, neither does it on the website. first off, you have to get the rods bushed because the pins are smaller. Now I have them fitted, they stop 1/4" short of the deck. Im pissing furious they never told me anything of this, just that theyll go in. now i either get longer rods and bush them, or get new rods and new pistons. rant over Edited by Leonard on 30th Mar, 2006.
1300 Posts Member #: 829 Post Whore essex |
29th Mar, 2006 at 10:57:30pm
Do you mean 1/4 of inch down the bore at deck i think you need S rods ? 1293 Turbo mini
30th Mar, 2006 at 12:48:43am
Think low hieght pistons are .090" down the bore on a std crank
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
30th Mar, 2006 at 01:02:16pm
1/4" is rediculous, get onto minispeed and ask whats going on. Whats the engine btw? I've seen the future and tbh its Pie
30th Mar, 2006 at 01:19:08pm
hmm low comp!
AlexF |
30th Mar, 2006 at 03:14:51pm
Well, there you go. Whilst a stock block could possibly 'just' take a 1/4" being milled off it, it's definately not good for applications like the K1100 head conversion.
30th Mar, 2006 at 03:18:47pm
I think you definately need to go back to the supplier with this problem, there is not a lot you can realistically do to be able to make practical use of these pistons.
30th Mar, 2006 at 03:38:20pm
couldn't they be used in a long stroke motor? or am i way off the mark? On 20th Oct, 2015 Tom Fenton said:
30th Mar, 2006 at 03:52:55pm
Good luck complaining to Minispeed. there customer service is appaling.
30th Mar, 2006 at 03:59:25pm
Anyone got a mini Piston to hand (that isn't a JE)??? Give us a quick measure of the comp height (distance from centre of pin to crown) so we can compare it to the JE... On 17th Nov, 2014 Tom Fenton said:
30th Mar, 2006 at 04:05:33pm
Just Measured a 10cc Omega, 37mm or near dammit.
30th Mar, 2006 at 04:09:35pm
Std pistons are 1.497in comp height.
30th Mar, 2006 at 04:28:52pm
Well - I was emailed a pic from the side of the box that JE pistons came in (you know who you are On 17th Nov, 2014 Tom Fenton said:
30th Mar, 2006 at 04:43:55pm
Add the 0.225 to the std stroke of 3.2in you get 3.425in or 87mm.
30th Mar, 2006 at 04:44:29pm
30th Mar, 2006 at 05:26:10pm
I can only think someone screwed up when ordering them - and it hasn't yet been rectified....
612 Posts Member #: 414 Post Whore Dalbeattie Scotland |
30th Mar, 2006 at 05:33:31pm
They wont melt thats for sure.
Edited by AllanMcD on 30th Mar, 2006. |
30th Mar, 2006 at 06:33:23pm
thanks for the replies guys. im just annoyed because thats the kind of thing you should be told when you order something. i spoke to minispeed, and they say to skim 250 thou off the block. the bloke reckons hes seena block that was skimmed down to the f of 'wfm' on the side. im gonna send the pistons back. the annoying thing is i had the rods bushed for them because its a smaller pin. so im on the look out for some a+ rods now! does anyone know if the accralite pistons are standard pin to top of piston height?
30th Mar, 2006 at 06:34:38pm
by the way i worked out comp ratio would be about 7.3 with a standard head!!!
30th Mar, 2006 at 07:05:13pm
Speak to one of the well respected engine parts suppliers and see what pistons they recommend for you.
30th Mar, 2006 at 07:06:08pm
they must be made for a different application.
30th Mar, 2006 at 07:20:19pm
they never told me when i bought them about the pins or the height. they use them in their turbo engine kit with modded standard rods, so i suppose they must skim all of that off their blocks? this is all their site says about them
30th Mar, 2006 at 07:30:35pm
Personally before spending £400-odd, I like to have an in depth conversation with the company selling whatever it is, not read the website and be done with it.
30th Mar, 2006 at 09:36:46pm
i ordered them by phone, and it turns out that the sales person clearly isnt familiar with these pistons, so i was given misleading information. im going for big dish pistons, because i want a good chamber shape, this is the reason for me spending alot. anyway ive learned now so i wont be making this mistake again
30th Mar, 2006 at 10:00:36pm
It does ot stop and just skimming the block, what about the rocker geometry?..a bit out you can live with that will need a carefull look over... On 21st Jan, 2011 fastcarl said:
Thanks! ) and this says 1.272 compression height. Axel says 1.497, so the difference is 0.225" (5.715mm).
