| Home > General Chat > Turbo intake temp | |||||||
40 Posts Member #: 101 Member |
21st Mar, 2004 at 09:37:46am
Just got round to fitting my air intake temp gauge. The sensor is tapped into the plenum (obviously reading the temp of the cooled air after the cooler) however I need to set the warning light on the gauge for maximum temp, so I can avoid melting 1. Expensive engine parts 2. My wifes patience...again! |
21st Mar, 2004 at 10:38:08am
That should be 'do you see'.......too much alcohol, not enough sleep. |
21st Mar, 2004 at 12:19:18pm
I am about to fit one...
AlexF |
21st Mar, 2004 at 01:02:37pm
Only been out in the evening..
21st Mar, 2004 at 02:35:38pm
That's quite impressive ! What intercooler ? and what kind of boost you running ?
21st Mar, 2004 at 02:40:53pm
bear in mind at nite its bloody freezing just now, i was out last nite, and my humble std radiator was over-cooling... tho i may be running slightly rich. turbo 16v k-series 11.9@118.9 :)
21st Mar, 2004 at 04:02:10pm
yeah what intercooler is that and how much boost? AlexF |
21st Mar, 2004 at 05:30:26pm
I'm running a bespoke charge cooler from PACE. I'm also running 16psi.
21st Mar, 2004 at 05:43:47pm
If you check out this link you can see the charge cooler, you will notice that it uses quite a large pre-rad (the smaller rad is an auxillary in line off the main rad)
Edited by AlexF2003 on 21st Mar, 2004. |
21st Mar, 2004 at 08:35:11pm
well the lower the better
AlexF |
21st Mar, 2004 at 08:57:59pm
alex i think you'll find it even higher than that, just depends on the engine spec.
Edited by Miniwilliams on 21st Mar, 2004. Best 1/4 mile 13.2 seconds @116 mph
21st Mar, 2004 at 09:59:15pm
I didnt specualte what the std setup makes... but I calculate it on apaper to be well over 100 degrees C!!!!
AlexF |
22nd Mar, 2004 at 12:25:00am
Alex, my folt what i meant was you'll find the 30-40 degress is not a bad intake temp, it will probably be hotter than that before things met.
22nd Mar, 2004 at 07:42:16am
I put a temp probe before and after my intercooler and I think I got about 95 before the cooler and 30 after it.
22nd Mar, 2004 at 05:20:32pm
Thanks guys...I think I'll set it at 40C...that should give me ample warning before things go boom. |
22nd Mar, 2004 at 05:49:57pm
In all fairness its not really a guage which is going to help u detect if somthing has gone wrong with your engine...
AlexF |
23rd Mar, 2004 at 11:06:52pm
At Avonpark last year, I saw inlet temps of 75 degrees
23rd Mar, 2004 at 11:32:56pm
Jim and how was your engine after that?? fine i bet! Edited by Miniwilliams on 23rd Mar, 2004. Best 1/4 mile 13.2 seconds @116 mph
23rd Mar, 2004 at 11:38:05pm
yes fine mate, and that was with a std bk450 head gaskget and std 10 year old head studs
23rd Mar, 2004 at 11:42:17pm
it does go to show that even if you see high temps it doesn't mean no more engine, nice bit of info Jim. Best 1/4 mile 13.2 seconds @116 mph
![]() 52 Posts Member #: 75 Advanced Member |
24th Mar, 2004 at 10:42:16am
What kind of intake temp gauge, are you using? |
24th Mar, 2004 at 10:47:43am
Jim's got data logging on his ECU the flash git AlexF |
24th Mar, 2004 at 04:58:26pm
I'm running a SPA dual digital - intake temp and boost pressure.
24th Mar, 2004 at 05:10:16pm
I have seen these forsale, but thought them to be a very bad idea. If you spray C02 on your intercooler, yes it will cool it down, but where will the c02 go? if it goes into the air intake, the engine will loose loads of power On 15th May, 2009 TurboDave said:
969 Posts Member #: 47 Post Whore Not very sunny swanage |
24th Mar, 2004 at 07:57:54pm
why will the engine lose loads of power if co2 gets into it? might well be being thick, but surely since co2 cotains oxygen, then it cant be that bad, its not like its starving the car of air or anything?
And on the 7th day........... God created turbochargers! |
