Home > General Chat > Just over 2 weeks to go!
Nick
Member #: 154
Midlands
Well times running out now. how much work you lot got left to do to make it to Avon?
I've got the week before off work and in that time i'm pulling the engine out, replacing a few leaky gaskets so they'll let me run. New clutch plate. few bits of welding. make my seats lock down properly. then i've got to rebuild my carb and go get it rolling roaded.....should be fun.
i've got to finish all the install off and get it rolling roaded! hmm when shall i run it in.... nah give that a miss!
frog probably wont be there. :/
Nick
Member #: 154
Midlands
whats up with the frog dude?
I've not a lot todo,
machine my pistons
make plenum chamber
make exhaust manifold
mount new rad
make new water pipes
make new intercooler pipes
make swirl pot for fuel
make swirl pot for water
wire up injection
rolling road (booked!)
suspension setup
wash
frog needs to be set up, and im really worried abotu the turbo
when and where you having the RR jim? emerald? i need to get mine booked in as well somewhere!!
I'm booked it at emerald the Thursday before avon.
cool fella, i'm hoping to have mine done at MBE the same day. just trying to get hold of them now!
Best get back in the garage!!
Ric
Member #: 36
Basingstoke
Jesus Jim, that's a massive list of stuff to do.
I'm just going to take my golf and run that on the Saterday. Really looking forward to it though. *happy**happy*
Alex... hope you get it sorted dude, would be wicked to see the frog run. :)
Mine is already on the trailer and full of fuel, so scratching my arse is the most I have to do.
However, the ongoing development of this car means that we have to modify the rear subframe to allow us to get some toe-in, and we're changing the fuel tank back to the old one.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I lapped in 2 of the 8 valves last night...
so to finish my engine I just need to fit the head, transfer casing and flywheel/cluth.
Then engine in car and run it in :S
Sounds easy - till you take out the week and a bit I am away in germany on work :(
AlexF
which car are you bringing alex?
Anton
Member #: 764
Staffordshire
my car is still running the 1100 engine atm... while the new engine is waiting in the kitchen for its cylinder head to arrive from morspeed...
before it can go in, i need to fit a bulkhead box, and create a new loom too.....
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
scooby?
or if I can the glittery one :)
shouldn't worry you top runners *tongue*
AlexF
well i've spent all afternoon out in the sun wiring the ecu.
think its ready to rock and roll, although just for first fire as i havent made a TPS adaptor or and temp sensors.
all wired in and in place though so it should be straight forward...
good luck iain, you have my number if you get stuck
dave also put your map on which is nice.
ecu all connected to lappy and working, just got to fudge the tps for the mo and then these last two wires *smiley*
cheers mate, may speak soon! ha ha!
ahh good, so you have a starting point then
DO NOT REMIND ME, PLEASE!!
turbochargedstu
Member #: 908
gateshead
wish i was going. *crying*
balls to the blower!!!
im in one piece!
still time for disaster though so ive got the week off work before just incase some hammer action is needed
Turbo Tim
Member #: 177
Avon Park 2006 Class D Winner
Woburn Sands
just turn the key and drive it there hopefully.
16V project underway
i had another rolling road and all seems ok, so fingers crossed for 2 weeks, but the poor old girl has been getting a real hard time of things of late so who knows!
Star Mag
Member #: 375
Leicestershire
I have got to paint the front end and doors, Pass mot, shouldnt be a problem as its freshly built, run-in, setup, setup suspension, sort any niggly problems. but hopin too have it sorted i too have the week off before avon!!!!!!
