Home > Show Us Yours! > K1275RS
Oli
Member #: 1910
Wilts
looks very factory and sounds lovely, good job.
Carl
Member #: 95
liverpool-on-sea
about fooking time!
well done, see you up the orme.
Good stuff!
What was up with the ECU in the end? Had you put a resistor in backwards or was it deciding that if it was going in a mini, it may as well act like a Lucas?
Dave, I have no idea, Andre and Matty never had a problem, and we are all using injectors from the same family. I recon it was that board, it was a replacement for the one with shorted WBO2. I fitted IGTBs instead of the FETs, and its fine, all be it the IGTBs are twice the price, but thats buttons compared to a new ECU. I never had any of these problems last year.
Been out for a drive tonight, and does it growl or what! I'll be grinning for the next month *happy*
indeedy:)
12 month ticket in my hands *happy*
The MOT testers face was a real picture when I opened the bonnet *hehe!*
lol,
was was it acompanied by "faaackin ell!"
Indeed it was, and that was folloed by, what is it? Rover K?
LMAO
LOL
Good stuff mate! How'd you do on emissions?
LMAO
"sort of....."
evolotion
Member #: 83
Glasgow, Scotland
bout time and glad shes on the road :)
Denis O'Brien.
dn89mini
Member #: 1506
Cheshire
Nice one. I like the new look with black arches too.
Check out the (slow) progress at.......
http://www.turbominis.co.uk/dn89mini
The arches are only temporary *wink*
Co 0.62% and 222ppm HCs
and, when I get the cat fitted, that will zero them right out*happy*
Thanks mate
LMAO
"sort of....."
Eh no, lol
my response was 'no mate, its a Mini engine' and the next response was 'No!? Really?' *hehe!*
Was funny when he shouted across the yard 'ere come and have a look at this, you'll never believe it' *laughing*
uhmmm yes.
rover bottom end
k-series top end (all-be-it BMW)
*happy* lol
Nice one Colin, what did you do for a head gasket in the end? did you go for the old hot water tank?
Lol
No, the hot water tank is still in one piece. I ended up using a BK450 with a few extra holes knocked into it, much against my own feelings of them. Time will tell*oh well*
First 55miles on a run out tonight went without fault, other than a few stalls when you lift off, but thats because the map isnt right, the wideband control is pulling fuel out, then when you lift off, it doesnt respond fast enough and stalls, that'll be sorted on the dyno *wink*
Oil pressure is a bit of an issue, i'll need to check the relief valve.
Dyno session was yesterday and it was not without issues, nothing major, but mapping the ignition was aborted. there is a little more power (3bhp I would hope to take me to my lower target) to be gained in that area alone, or at least thats what my mapper tels me.
Also remember that the inlet cam is the lower lift shorter duration item, so I think the final results so far are on the money.
I think i'll bung the RS inlect cam in it before the dyno shoot out *happy*
107 bananas at 7300rpm and 81 curlys at 6400rpm.
It drives amazingly well, thats the bit that really matters and, if anything, I am at the same level as i was with the 1400, which is all i really wanted. I would have found it hard to accept if it was anything less than the 1400
Good starting point. Over 100 bananas is great for 1275cc
Paul
Oli
Member #: 1910
Wilts
I guess thats at the wheels then? LOL
Edited by Oli on 24th Dec, 2008.
er, it has no wheels...
DIME BARRRRRR
http://uk.youtube.com/watch?v=aEPorptkRPs
Little bit of a drive out, panic moment and comedy highlight *hehe!*
The printout says at the flywheel, but im not convinced its right. The only acurate reading you get is at the hub, and I didnt pick that printout up, but im going back so I will make sure i pick it up.
