| Home > Show Us Yours! > My hillclimber in the making (998 Turbo) - Gone | |||||||
4th Apr, 2009 at 06:17:22pm
On 30th Mar, 2009 GaryOS said:
On 30th Mar, 2009 slater said:
am i understanding the subframe mounts right, your raising the subframe in relation to the car yeh? Yeah, that's what he's doing. You cut the ring off the top of the subframe towers and make a spacer (or maybe you could use the 2 alu. tower mount spacers if bodging) to prevent the tower bolt from bottoming out. It is in order to reduce the angle of the top arm on seriously low cars. I think Jimster had a thread on it previously Yep, spot on. Isambard Kingdom Brunel said:
4th Apr, 2009 at 06:20:25pm
A bit more progress:
458 Posts Member #: 1840 Senior Member Kings Lynn, Norfolk |
4th Apr, 2009 at 06:51:44pm
Looking good buddy, just a side note, have you checked elbow clearance on the door bar, as mine is a little too high for my liking now. |
5th Apr, 2009 at 01:27:55pm
I've checked my elbow clearance and it's all good, I initially mocked them up with a bit of string and must have had the seat in and out a dozen times before I was happy.
5th Apr, 2009 at 05:20:14pm
And I made a bit more progress after watching the Bernie & Max show this morning:
5th Apr, 2009 at 05:23:38pm
Looking good. Nice work. :) |
![]() 646 Posts Member #: 1826 Post Whore Maldon Essex |
7th Apr, 2009 at 10:12:21am
I don't suppose you've got a picture of the subframe towers.
7th Apr, 2009 at 08:49:54pm
Andy, my subframe towers are currently as they left the factory, although they will be getting tweaked later.
8th Apr, 2009 at 09:36:28am
Wow looking very good. |
8th Apr, 2009 at 09:36:34am
8th Apr, 2009 at 09:41:09am
Rob the rate at which your completing this projects is clearly out line with TM SOPs. That said it's quality work! On 7th Nov, 2008 Nic said:
9th Apr, 2009 at 05:30:35pm
Back end nearly finished :)
10th Apr, 2009 at 06:36:57pm
Broke my drill so ended up making a rear gusset:
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
10th Apr, 2009 at 06:57:25pm
Great work Rob! Looks top notch.
the pissed up clown stood back up, did a twirl and left bollock naked, |
10th Apr, 2009 at 07:16:46pm
On 8th Apr, 2009 Jay#2 said:
Rob the rate at which your completing this projects is clearly out line with TM SOPs. I don't know, it's taken a little over two years to get this far. On 10th Apr, 2009 mini_surfari said:
Series 2/3 landrover steering wheel i see? Not quite, it's actually off the Midget (first thing I did to the car was to fit a Motalita one) just using it for mock up and keeping the decent one clean. Isambard Kingdom Brunel said:
10th Apr, 2009 at 08:06:05pm
Crap, should have known that seeing as i had one in my midget lol. On 15th Jul, 2009 fastcarl said:
10th Apr, 2009 at 08:55:14pm
Looking good rob,
12th Apr, 2009 at 06:17:20pm
On the home stretch now, just the passengers door bars to do. Annoyingly I blunted my last hole saw this morning and every where was closed other wise I'd be done.
667 Posts Member #: 1376 Post Whore clock tower with a sniper rifle |
12th Apr, 2009 at 10:35:33pm
Looks very beefy, top work! internationally known as "big" swede |
13th Apr, 2009 at 03:50:04am
Awooooooooga |
13th Apr, 2009 at 04:14:39pm
Finished:
13th Apr, 2009 at 04:57:02pm
and here's the left overs:
13th Apr, 2009 at 06:28:26pm
Great work!
559 Posts Member #: 2775 Post Whore Aberdeen |
13th Apr, 2009 at 07:38:48pm
Dont want to piss on your parade! But you are a long way from finished. You still need lights engine wiring etc |
13th Apr, 2009 at 08:29:28pm
also looks like you still got one more to weld....
