Home > Help Needed / General Tech Chat > Brake probs
Dangerous
Member #: 417
On 9th of Nov, 2006 at 10:30am fastcarl said:
i just use the standard 3/5 bore master on both my cars wioth 4 pots, pedals short and solid.
have you mad esure your rears are adjusted right up.
You can tell if the rears want adjusting---Try driving around with the handbrake up a few clicks,If they work better they need adjusting*wink*
Also what size rear cylinders have you got,Think you need .500" for single circuit-If you have bigger ones the rear brakes work better but use more fluid so resulting in more pedal travel
Edited by Dangerous on 9th Nov, 2006.
