Home > General Chat > giallofly's warped block.,
you can always thank fav for great sound effects!
Jon were you using arp's then? as i found this on there website
"The front stud on the 11 stud head should only be torqued to 45 / 30 ft lbs as the block is open at the water pump, and will start to distort if more tension is put on the stud."
giallofly
Member #: 164
The Stig..
Newport Pagnell
Blimey....this is an old thread....
The block was well warped and ARP componants are used throughout....
Jon.....xxxx
On 05/05/2004 21:57:26 minimark said:
If it runs sub 13.5 its mine and i`m taking it back..
So mark, are you taking it back?
Stig
Member #: 694
Shropshire
On 07/05/2004 15:37:09 AlexF2003 said:
giallfly AKA the stig!
oi thats my name :p
