| Home > Show Us Yours! > it lives egor! - 1293 8v Bimmer Twinky | |||||||
703 Posts Member #: 105 1st to provide proof of a running Bimmy Conversion! Brisbane ,Australia |
8th Jan, 2007 at 02:36:02am
well done John & Antman... they`re really not that hard to do at all are they? www.miniman.com.au
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
8th Jan, 2007 at 07:43:45am
At least we know where all the heads are going then!!! Good job i bought my 16v a while ago i wouldn't be able to afford one now!!! |
1425 Posts Member #: 690 Post Whore Norfolk |
8th Jan, 2007 at 10:53:27am
Hi Matt - no not hard - the hard bit was building the engine/gbox and the car itself in about 11 weeks flat - at evenings and weekends only!
If Carling made Mini engines
8th Jan, 2007 at 02:13:51pm
yeah, to build a good mini takes a while but you`ve done well for the time
www.miniman.com.au
8th Jan, 2007 at 03:24:52pm
sounds like a plan - have you strapped a turbo on the runner yet? If Carling made Mini engines
10th Jan, 2007 at 01:03:38pm
well, we did,,, but the old computer wouldn`t play the game very well at all,,, it made noises , just not very good ones www.miniman.com.au
10th Jan, 2007 at 02:30:42pm
Someone get a K head turbo A series running and on a dyno quick! The suspense is killing me! On 7th Nov, 2008 Nic said:
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
10th Jan, 2007 at 04:20:33pm
i believe it's already been done... |
10th Jan, 2007 at 06:14:41pm
Oh I know but no figures yet. No vids of one running either. On 7th Nov, 2008 Nic said:
314 Posts Member #: 1311 Senior Member Yeovil, Somerset |
10th Jan, 2007 at 06:22:40pm
Sure theres a vid of it running somewhere
10th Jan, 2007 at 06:34:02pm
I know there are videos of a running (and driving!) turbo'd K headed mini as i was there at the time. (check the main site video page!)
10th Jan, 2007 at 06:57:47pm
On 10th of Jan, 2007 at 01:03pm MadMatt said:
we`re not far away, the big problem i`m having is that the 8v kit bits are slightly different to the 16v kit bits, so we`re perfecting all the differences between & dummy-ing them all up to make sure they`re all sweet before we jump the gun & stuff all my bits back onto my donk. What differences have you found? I was under the impresion that for conversion pieces they are the same ...... Would be great to know what to look out for. Every day is a school day ...........
10th Jan, 2007 at 08:31:48pm
there was a figure for jimsters in a mag, just over 200 nana's on emaralds rollers but there was an issue with something that was limiting power, i think it was the wastegate cracking open.
10th Jan, 2007 at 08:38:24pm
Yep. Wastegate issues with the T25 on there not bypassing enough, and boost creeping up with rpm (limited to 6400 I recall).
Edited by turbodave16v on 10th Jan, 2007. On 17th Nov, 2014 Tom Fenton said:
10th Jan, 2007 at 09:07:33pm
That's pretty much what I mean, would just love to know what it would have been capable of without the turbo trouble on the dyno and when it's all fully sorted. On 7th Nov, 2008 Nic said:
10th Jan, 2007 at 09:25:42pm
Jim is keeping his cam profiles, timing and turbo specs to himself IIRC - I dare say he'll post up some dyno stuff - but the drag strip is where the results will really be seen On 17th Nov, 2014 Tom Fenton said:
11th Jan, 2007 at 12:30:54am
On 10th of Jan, 2007 at 08:38pm TurboDave said:
and boost creeping up with rpm (limited to 6400 I recall). more boost more boost
11th Jan, 2007 at 06:04:29am
ok, essentially the 8v & 16v bimmer heads are much the same in overall dimentions & the bolt patterens , pulley bosses etc dept, the differences (apart from only being 8 valves in one of them & 16 on the other & the 2 different cam shafts to suit etc) is that the lower & upper alloy flange conversion pieces that help seal up the front head plate are different... the lower section of the front of the cyl head is a slightly different shape where our sealing flange fits & also the cam covers are a different shape where that upper flange sealing bit fits.
www.miniman.com.au
11th Jan, 2007 at 06:14:39am
IIRC Jimbo ended up using the 'dowels' in the cam journals - just as you describe - to locate the front plate before doweling it to the head...
& i have 12 x 8valve heads here & 6 x 16v heads , yeah i`m a greedy bugga hey?
more boost
