Home > General Chat > CRs fao mark
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
No drinking???
Jim will be most upset at Avon park... I think theres a whole Keg to get through!!!
AlexF
minimark
Member #: 19
newcastle
"does it really matter? "...not at all
"FFS Mark just get on and build your next car"...making a start today!!!
giallofly
Member #: 164
The Stig..
Newport Pagnell
You've lamped me several times when you where pissed mark!
I know you don't remember as totally ratbagged!, that was after 2 halfs of lager and lime too!
Anyone remember "brownbottle" from Viz???, the pissed up Geordie super hero...it's Mark!
minimark
Member #: 19
newcastle
there`s not a little smilely for humble pie so i`ve writen it instead.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
lol yes I remember Jon!
So what you got to do to the new car?
Is it going to be FUN?
Alex
AlexF
minimark
Member #: 19
newcastle
I know this is very sad ........simon who used to run or maybe still does run viz, lived round the corner from my shop in jesmond, he is into mini`s thats how i got to know him , didn`t know he was any one well known or anything.
He did a feature on sudent life in jesmond , which is the big student area in newcastle.
Anyway on the map in viz he marked my shop and put it down as the porn place ( pre internet) and watch out for owner in his turbo mini , fastest paperlad on tyneside.
Very sad isn`t it.
claim to fame mate, have you got a copy of that mag, make a good image for sheepspeed
minimark
Member #: 19
newcastle
no , never thought to keep it
do you know what issue?
minimark
Member #: 19
newcastle
got to 8 or 9 year ago
ok, maybe I should put a thread in the wanted section
mark4765
Member #: 249
i think your figures are wrong alex....whats your deck height,gasket bore and gasket compressed thickness
mark
Edited by mark4765 on 14th May, 2004.
jukka
Member #: 60
Forgotten more than most ever know
If you don?t know the deck height assume the worst. Std bore engine has roughly 4 cc?s of cylinder volume for each 1 mm (0,040") that the piston is below the deck. So for 5,25 cc the pistons should be something like .050" down the bore. I doubt that. I?d recommend that you re-calculate with .015-.020" to be safe until you really measure the actual value.
I usually use 3,5 cc volume for combined head gsaket + ring land volume, this way the possible error gives me too high a CR compared to actual compression.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
With your figures Jukka... I get 7.7:1 CR
Anyway wants to have a look or play with figures... goto
www.afracing.com/cr.xls
Alex
AlexF
mark4765
Member #: 249
i got 7.76:1 alex using this...the best comp ratio tool ive seen... http://www.maverickracing.co.uk/compratiosoft.htm
Edited by mark4765 on 15th May, 2004.
so what do you make mine then, with 10cc omegas +020 and 30cc head
mark4765
Member #: 249
need deck height in mm,gasket compressed thickness(measure old one) and bore size of gasket
regards mark
I'll measure it next week while the heads off. The gasket is a bk450
Edited by Jimster on 15th May, 2004.
minimark
Member #: 19
newcastle
Edited by minimark on 15th May, 2004.
Alex - just checked one of my spare 'turbo' engines. The pistons aren't machined so are a bit tricky to measure the height from the deck to the squish band - so i took three measurements.
0.1
0.4
0.25
hence, taking averages, you can assume the pistons are 0.25mm down, and on a 1275, this is just shy of 1cc...
The 'turbo' pistons defiantely sit higher than the nat asp ones...
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
how many thou is that?
alex
AlexF
minimark
Member #: 19
newcastle
10
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Bore 70.61mm
Stroke 81.4mm
Gasket Volume 4.00cc
Ring land Volume 0cc
Piston Volume 12.00cc
Head Chamber Vol 30cc
Deck Volume 1cc
I make that Compression Ratio 7.78:1
so I am probably between 7:1 and 8:1.. which is fine as I'm happy with 8:1 amyway *happy*
Alex
AlexF
mark4765
Member #: 249
i make that 7.7897:1 alex *laughing*
Edited by mark4765 on 16th May, 2004.
minimark
Member #: 19
newcastle
sorry not acturate enough for me, i`ve run the figs through a number of PC`s and came out with ..
about 8/1 ish canny for aboooot a bar .
