| Home > Technical Chat > crankshaft pulley Nut | |||||||
375 Posts Member #: 886 Senior Member London. |
27th Feb, 2007 at 10:32:36am
lol.. sorry i meant to say 32m wont fit..
27th Feb, 2007 at 11:17:19am
Behind the Crank pulley bolt there is a locktab, a thin washer that can be folded up against the bolt to prevent it coming undone, if present this needs be folded back.
2nd Mar, 2007 at 12:26:59pm
Just got round to doing this bolt lol
![]() 2641 Posts Member #: 19 Post Whore newcastle |
2nd Mar, 2007 at 12:35:35pm
feel all round the nut to make sure no bits of lock tab are still present .if not .. its all down to muscle power ... a long bar and plenty of brut strength is required. someone standing on the brakes will its in gear might help Everyone knows that instructions only have to be read if the thing doesn't work....
2nd Mar, 2007 at 01:13:03pm
Got it off :)
2nd Mar, 2007 at 01:13:22pm
i remember reading that a dab on the starter should get it undone anyone tryed that? On 28th Aug, 2011 Kean said:
2nd Mar, 2007 at 01:24:22pm
you should be able to wiggle it off, its a tight fit, but it can be done (on the ones ive done anyway) "Turbo's make torque, and torque makes fun"
2nd Mar, 2007 at 02:56:19pm
Just got some wood and taped it off.
4th Mar, 2007 at 02:44:50pm
anyone :) |
4th Mar, 2007 at 02:51:33pm
oil kills belts, so get it changed before it snaps :) as for the mounts, just persevere. turbo 16v k-series 11.9@118.9 :)
4th Mar, 2007 at 03:38:54pm
engine mounts can be a nightmare, welding the nuts on before hand can help, but only if theyre carefully lined up, the last 'captve' nut mount i got from minispares didnt, meant i had to elongate a hole in the subby to get them in.
4th Mar, 2007 at 08:38:39pm
How did the oil get there in the first place ? |
4th Mar, 2007 at 09:22:10pm
the nuts have been welden on the back :). can only get the top bolt on.
4th Mar, 2007 at 09:27:09pm
The last time I change my clutch oil seal, it took two long crowbars to get the engine mount to line up, one pushing it sideways, the other pushing it down.
4th Mar, 2007 at 09:55:58pm
ive had to 'press' engines into the subframe (with ratchet straps/mate stood on engine) due to misaligned 'captive' nuts.
4th Mar, 2007 at 10:04:01pm
The reason I always use genuine mounts .... never had a problem with them.
5th Mar, 2007 at 12:27:38pm
roger, i know what you mean.
