Home > Technical Chat > clutch master cylinder
Ben H
Member #: 184
Melton Mowbray, Pie Country
Yes, the pin that joins the pedal to the fork on master cylinder.
http://www.twin-turbo.co.uk
Wile E. Coyote
Member #: 7893
Portsmouth
Mine is rammered in there rediculously,
allmost seems to hard to push it out, and i gave it some welly before....
Hmmmm, persevere i suppose,
just first time doing this thats all..
am i right in thinking there isnt a gasket between the Cylinders and the mounting plate ? i seem to remember seeing somewere that there was, but couldnt see the point......
Jamie.
mine was rusted. I think I managed to tap it with and hammer and a punch.. right pain but had been in there for more than 30 years..
Edited by gr4h4m on 28th Jan, 2010.
Wile E. Coyote
Member #: 7893
Portsmouth
Yeah same as mine probably, doing a 79 Clubman,
ill take the brutish approach ! :0) cheers all, just the gasket thing i need to find out.
Jamie.
Ben H
Member #: 184
There is a gasket between the mounting plate and the bulkhead, on my 1990 car there is anyway. It is a very thin rubber job. I think there is one between the cylinder and the plate too. You need to stop water getting in so gaskets are required.
