Home > Ebay items For Sale > A different approach
Allright people. Mods have started. I'm getting some 1100 Hypatec pistons for this engine and will be modifying a 202 head for it. I guess I should aim for 9ish in compression. The exh housing is a .25, so it look as it is a std Metro turbo. Bar the lag, isn't this a good choice for a near standard Small bore? Wil and Ben??
Not sure which camshaft to use either, but I guess something similar to an MG Metro will do the job.
I have been working on this a bit more, and it seems as it is a T3 turbo. However, the exh housing is A/R24. The Metro ones are 25. arent they? SO, Dave, what does this mean? :) Practicly of course.
Bugger all difference I'd say.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
If I recall, was this the one with the turbo between the carb & engine? If so, heres a question. With that setup, would you have the seals in the carb the same way round as a n/a engine?
Edited by Jason G on 25th Aug, 2008.
