| Home > General Chat > front mounted radiator in a roundy front who uses them | |||||||
![]() 9326 Posts Member #: 59 First mini turbo to get in the 12's & site perv Herefordshire |
16th Jul, 2007 at 11:44:47pm
On 16th of Jul, 2007 at 11:17am Jimster said:
I've got a nova rad in the front of mine Piss off to migweb..... |
16th Jul, 2007 at 11:54:15pm
Pffffttt!!!!
11th May, 2008 at 07:23:43pm
On 15th Jul, 2007 Rob H said:
I'll be putting an MPI rad in the front of the Bloody Open Classic in the next few weeks (if I can find some time) I'll post some pics when I'm done. Well I finally got it fitted: Never again mind, it was a real pig of a job. Has anyone else gone down the MPI rad route? did a bit of searching but no real luck. Isambard Kingdom Brunel said:
11th May, 2008 at 09:48:45pm
in that case flip i belive this my be of use to you |
12th May, 2008 at 12:05:20am
how do you bleed the coolent system with a fully seald rad? thats the one thing im not sure about, if its pritty easy i may go front mount rad as well as Ic Drives
12th May, 2008 at 07:42:48am
You need a header tank thats located higher than the rad, so the air rises up the pipe. Simple. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
12th May, 2008 at 05:56:15pm
cheers :), i thought it may be abit more complicated than that lol. on peugeots you have a few bleed nipples i didnt know if you had to install one or somthing like that =/ Drives
