Home > General Chat > Who has a rollcage?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Better than nothing....
It WAS FIA approved at one point.....
Alex
AlexF
i've got a climbing frame as has been mentioned!
its ace, i also have corbeau revolution seats and 6 point harnesses so there is no way my head could hit the cage that i can think of.
it will have very little road use mind, and therefore the vast majority of time i will be wearing a helmet.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
Are the roll centre tubes in the weld in cages delivered notched? or do you need some tool to do that also?
You have to notch all the tubes yourself, a bit of a pain but it means that you can taylor if for the car, also keeps the cost down.
Carl
Member #: 95
liverpool-on-sea
bet this guy was glad ne had a cage
http://www.16vminiclub.com/forums/viewtopic.php?t=10074
Wow carl thats how the cage saves you.
http://cgi.ebay.co.uk/Mini-Vtec-Watsons-Su...1QQcmdZViewItem
no cage...
Hedgemonkey
Member #: 360
6 point. SD
Let's face it, if you have a big crash in a mini, you're going to be badly hurt and a good strong front ender will see you cop the dashboard on your legs. I have got a couple of bits of lagging here and there. I think the only hazards are whacking your head on the diagonal/top bit. The one above your right ear isn't much of a snag.
I fitted mine to stiffen up the shell and I'm probably going to add "ears" and weld it to the shell a posts and wherever else looks like it would help.
