| Home > Technical Chat > Metro turbo cutting out | |||||||
104 Posts Member #: 1870 Advanced Member Aldershot (we are top of the league, say we are...) |
23rd Aug, 2007 at 06:49:23pm
Well have done some more checks this evening, i T-pieced my fuel pressure tester into the tank return, showing about 0.5psi took the fuel cap off and you can see it quite nicely trickling into the tank with enough force to hit the other side of the filler neck. Took it for a spin and the further i drove the pressure seemed to be gradually increasing to a max of 1.5psi then as the car lost all go (always at the exact same spot on my test run) the tank return pipe was still on about 1psi. Pulled over and turned the engine off, took the fuel cap off and fired it back up and again you can see the fuel going back into the tank. Then to be sure everything pump wise was ok, with my pressure tester still connected to the return line. I clamped the return line slightly and the pressure gauge shot up and the car died. (flooded i suppose) Took a while before it would fire up again. Then drove the rest of the way home with no problems.
23rd Aug, 2007 at 07:14:54pm
On 23rd of Aug, 2007 at 06:49pm mg-metro-matt said:
What do we reckon then sticky needle valve perhaps telling the pressure regulator to turn off? could be some fit into the brass housing a bit tight and need filing to fit
23rd Aug, 2007 at 08:52:59pm
I have got a spare needle valve and float chamber seal so i shall give that ago. Never had a needle valve go on me like this before but hopefully this will fix it, im running out of things to try! lol
24th Aug, 2007 at 08:49:25am
Just had a thought guys, when i t-pieced my fuel pressure tester inbetween the pump and pressure regulator (tank side of the regulator rather than carb side of the regulator). When the car lost all its go the pressure still went to almost 0. Just had a think, when you short out the oil light and turn the ignition on, so the pump is running when the engine isnt, even though all the fuel is going to the tank return im fairly sure i still had 5psi on my fuel pressure gauge. So surely it shouldnt be normal for the fuel pressure before the regulator to go below 5psi even if its all being returned to the tank?
24th Aug, 2007 at 11:38:21am
if the tank/filter blocks then the pressure after the pump and before the regulator will drop even as low as zero.
24th Aug, 2007 at 11:45:23am
Well i no the tank pick up is clear as i have had that apart and made a new one out of a steel tea strainer! lol hmm i thought i had ruled out blocked hose from the tank, but maybe thats worth abit more investigation
24th Aug, 2007 at 12:10:15pm
How about giving the feed and return pipes a good blst through with an airline, see if you get any shit come out... On 28th Aug, 2011 Kean said:
24th Aug, 2007 at 12:10:44pm
pull the return hose off and see what sort of flow is coming out of that.
3rd Oct, 2007 at 09:21:52pm
Well just a progress report...
3rd Oct, 2007 at 09:44:27pm
Great to hear matt. Fine metro from the pics m8 On 19th Jan, 2010 wil_h said:
