Home > General Chat > For those doing Combe next month..
yes only cosmetic. cost me 2k in bits tho ? a plastic wing liner is £248 +vat wot a joke.
nic , had an escort cos , the v6 clio then briefly a focus rs , evo 7 fq300 and now the porka.
thanks tom il give it a go
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
Ouch, why didnt you save money and get the fibreglass bridger out? *tongue*
Youre lucky as it cudve been worse.
Class cars the v6 clios, rs's and some evos but dont take this rong way, never had a soft spot for newer porches. The 911 turbo from bad boys and gt are best.
ceramics?
http://www.youtube.com/watch?v=jx7tA4RYdGM...related&search=
Minis are my life but apart from that the cossie was the best altho v6 was good even tho i disslike french cars. allways wanted a porsche and this one come up at rite time, bad boys one is the best but gota be a proper turbo tho.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
I love combe ..... hate "action days".
They let too many people out at a time, most off which wouldn't know a racing line if it bit them on the arse.
I can push my car over Avon flat then get all the breaking done between then and the turn in point for Quary ...... sticky 13s and coil overs anybody ..... sorry could resist!!!! *wink*
Ah im looking forward to some combe action now! :)
Anton
Member #: 764
Staffordshire
ay... i cant wait! will be my only track action all year... just hoping to get my suspention setup between now and then...
at japfest they have clubs and types of cars going out in groups
Can us lot go round together on a closed track?
Jordan
Member #: 1392
Wish I could but id be annoying meself all the way round just incase i crash it and cant get home.
I have a tendancy of going overboard.
Carl
Member #: 95
liverpool-on-sea
wussy!*tongue*
Jordan
Member #: 1392
You going carl?
Carl
Member #: 95
liverpool-on-sea
On 30th of Aug, 2007 at 08:31pm minimadj said:
You going carl?
urm, dont know engines in buts again so if i can bw bothered to fix it then maybe.
ahh bugger
Take the bmw if not carl and give that a blow out on the track
Carl
Member #: 95
liverpool-on-sea
On 30th of Aug, 2007 at 09:15pm Nic said:
ahh bugger
hmmmm. shhhhh, dont tell the missus. "im just going to watch" lol
Jordan
Member #: 1392
She'll probably go in wit ya telling ya to take ya foot off the brake.
Whats up wit it now carl?
be very carefull chaps
Jay#2
Member #: 648
Northern Ireland (ex AUS)
It's amazing how much you accelerate when you hit grass!
On 7th Nov, 2008 Nic said:
naeJ
m
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I only found out your ment to brake before the rise after I'd driven the circuit a couple of times LOL.
Luckily it was in a slow mini so it didn;t matter.
These days I still don't worry about braking before LOL - ask Iain or Dan (I cant remember who it was) when I took them round in my old BMW 540 !!
Alex
AlexF
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
It sure feels like that!
AlexF
I remember the BMW driver crashing into the Lotus replica, if IIRC the BWM driver was driving like an idiot all day and had ben given serveral warnings.
Jordan
Member #: 1392
Are th tire walls effective on distributing the impact force?
There better than hitting a brick wall, but it's still advised that you avoid hitting them.
Jay#2
Member #: 648
My favourites have to be plow-on-understeer evo and Rover 25 man. I just cant believe the guy in the Lotus managed to dodge that Z3 coupe!
naeJ
m
RogerM
Member #: 1217
Are you guys really having to get your braking done before Avon???
My rev limiter (soft) is at 7000 (3.44 diff)and I am on that as I sweep across to the left for Avon then it needs to be maximum braking until the turn in point with a down change to 3rd, holds on well for Quary with just a hint of the tail coming loose then need to grab 4th again at Apex as I am back on the limiter imediately after if I don't.
I can't work out how I can do that if Jon F is saying to be off the brakes by the time you pop over the rise?????
Ok sticky 13" rubber (treated 048r softs) and big brakes (rover 214 discs (10.2") mounted on one off bells with radial mount willwoods so I can shrug the speed off but still doesn't explain it all .......
If I can get a day on the car before Combe I will bring her along ...... hasn't tuned a wheel since combe action day 2005 ..... bloody houses!!!
giallofly
Member #: 164
The Stig..
Newport Pagnell
Roger, you may well brake after avon, you do have a far superior brake set up than most provided it is set up well.
I certainly brake before Avon rise, settle the car , down to 3rd all while moving from right to left side off the track.
Always keep it STRAIGHT over Avon as the car will a a little light if carrying enough or too much speed.
I hit brake down into Avon from around 8000rpm (126ish) on boggo Metro turbo brakes with carbon metallic pads that are very well set up with the correct master cylinder front and rear and a carefully adjusted bias bar.
The tyres are 048's but untreated in medium, softs do not last the race before going off.
So tackling the trickiest part of the circuit in your car and your experience it will be the case!
I would ADVISE folk to brake before !
JF the Drayton Manor MG Metro Championship lap record holder!
http://www.msttiming.com/result.asp?table=...castlecombe.gif
Edited by giallofly on 1st Sep, 2007.
TBH, I believe it is possible brake after Avon, but it's not recommended if you are inexperienced on the track (like me) and probably worse if you don't know Coombe.
IIRC there are A4 posteres in the tavern stating that you are 3 times more likely to crash at Quarry than on any other corner.
That said it's the chicanes that throw me and I will hold my hand up to spinning in the esses.
Edited by Rob H on 1st Sep, 2007.
