Home > Technical Chat > Engine
Oh and jackman replaced the head gasket for an AF460 , drove it for bout 50 miles and the car was written off!! Poor fella, hes had a hard time of it. The engines still good though
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
+the 460 hg is made of cooper , it's far better to conduct heat than fiber,
T3Tone
Member #: 252
Sunny suffolk
IMO a 1380 will spool the turbo up quicker and give you more power/torque per Ib of boost. Ive run upto 18 psi on the rollers and use 16psi on the road with no problems and bk450 head gasket.
A 1293 will leave you with quite a few rebores before the block is scrap, slightly better on fuel perhaps ( not that it should be a concern) easier to obtain lower CR, cheaper machining and pistons.
-MINI CLUBMAN 1380 TURBO-
one thing to consider, is the fact that 0.5mm is near as damit 15 thou,
this also happens to be the amount that vizard recomends to offset bore the block when going to 1400 or more.
I have heard of people having issues with the BK450 on 1380's, some times due to running no deck height and having the piston touch the gasket and cause it to fail.
Scruffy
Member #: 328
Seaford Rise, South Australia
Comtec gasket is 74.6mm so no overhang.
On 5th Sep, 2011 Vegard said:
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Interesting Scruffy ...... off to check the UK stockests site ... I remember Sprocket posted up a link not long back.
In case I can't find it please remind us if the Comtec gasket requires the engine to be dry decked or not?!??!
It's COMETIC you ignorant people *wink*
http://www.cometic.com/
Scruffy
Member #: 328
Roger dry decking only required if you are from Norway:)
KAD sell them £60 ish - no retorquing required which is handy for me it is the Midget one you want that is 74mm and measures up as I stated
I agree with T3Tone, Stevie Benross has proven that 1380 Turbo Power is usable!
