Home > Help Needed / General Tech Chat > Leccy water pumps
Thats 13L per minuit at a maximum pressure of 10kpa. Id be surprised if the A series cooling system has less than 10kpa pressure drop across it, therefore the pump will actualy be doing less
Ive done some searching on these Renault 19 pumps...£30 from a breakers but still unsure on the flow rate?
What the minimum flow rate you can get away with?
AL
Member #: 1347
Croydon (South London)
http://cgi.ebay.co.uk/NEW-WEBASTO-EBERSPAC...1QQcmdZViewItem
what about this vag pump? IIRC they were on vr6's as a secondary pump?
miniminor63
Member #: 672
The oversills police
Oslo, Norway
yes, and almost all secondary pump have a low flowrate. I will stick my head out and claim I would not use less than about 25-30 litres a minute . I have never tried anything with less though, so are okay being proved wrong:) I have a mercedes secondary pump thats putting out about 18-19 litres somewhere, cheap if you want it...
