| Home > Help Needed / General Tech Chat > PLEASE HELP WITH NEXT STEP :( **setting fuel pressure?** | |||||||
5th Jul, 2004 at 10:00:25pm
cant get there though its all the way in town
126 Posts Member #: 244 Advanced Member |
5th Jul, 2004 at 10:12:38pm
20/50 is the best but don't get expensive stuff at first, run some cheaper stuff for half an hour to get the petrol out of the system then put top 20/50 in. Speedster turbo under construction |
6th Jul, 2004 at 03:28:14am
lol sure theres something in some FAQ about that bolt... turbo 16v k-series 11.9@118.9 :)
244 Posts Member #: 34 Senior Member |
6th Jul, 2004 at 08:30:38am
As soon as I read this post, I knew what you had done!
6th Jul, 2004 at 10:29:26am
i just cant believe it. Ive just got back from town, got some 11 quid cheapy 20/50 oil to run it with down to town, then ill buy the 15/40 castrol maganetec i think :) Right, off to line up this enigne moutn again, got work at 1, hope to get it started before then! Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
6th Jul, 2004 at 10:31:47am
Keep us informed!!
6th Jul, 2004 at 01:00:59pm
ive hit a few problems.
6th Jul, 2004 at 01:07:44pm
can i just also mention, i also found a hole in my flywheel casing, not the wok part, the other bit inbetween that and the block, theres a chunk missing. Didnt see it until i removed the starter, its behind it :(
Edited by jamesfawcett on 6th Jul, 2004. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
117 Posts Member #: 144 Advanced Member |
6th Jul, 2004 at 04:18:39pm
mate! thats well harsh.
![]() 105 Posts Member #: 133 Advanced Member Jamaica |
6th Jul, 2004 at 04:34:43pm
On 06/07/2004 13:00:59 feebleuk said:
ive hit a few problems. Number one, should the cooper tank keep pumping even when the engine is not running, or does it stop when it reaches a certain point? Its not making sounds, and cant hear it at the same time i crank it over. So that could be the problem there. Ive got the oil pressure to 50, so thats fine, but the boost guage fllicks round to -20 straight away. The car turns over, and kicks in and gives it all to run, gets a few revs with a bit of throttle, but not for long it dies a few seconds after i let go of the starter it just stops. I also cant get the flywheel casing side engine moutn in now. How on earth do you do it. I can get them lined up above, but no matter how much i jump on the side of the engine it will not go down! I can wedge it down with a screw driver, but then the mount half just springs straight back up and i cant get the bolt in, its taken my most of the morning to try and solve. Is there a special tecnique to doing them? If i cant find a way, im going to need to take all the oil cooler and radiator off the other side to get to that one to undo it, but the exhaust and stuff aswell :( The third thing that i need to ask advice on is the MBC. at the moment its completely turned arround away from the +, so its set to zero. Does this mean the boost is released at 0psi? Is that why it dies? If i turn it round a few times, it will make it not open or something wont it? Im confused sorry about this. Im off to work now, ill be back at 5 to carry on with it! 1. the pump should stop when the engine is NOT running. If it is wired in correctly 2. the boost gauge reads vacum also which is what it shows at -20 it wont read boost until the turbo spools. i dont have any idea on why it wont run though :( 3. release the other mount on the radiator side it should go in easier when both mounts are released. 4. with the MBC set at zero then you would only get boost to the preset wastegate setting hope that helps
'I swear to use the Boost, The whole Boost'
6th Jul, 2004 at 04:39:38pm
pump will run if its set to come on with the ignition and is not wired thro the usual oil pressure switch. turbo 16v k-series 11.9@118.9 :)
6th Jul, 2004 at 05:42:26pm
ah, thats waht i meant. With live to the pump, and all the connections onto the carb, i was wondering if the back pressure made the pump stop when the engine was not running but key was in position 2 on the injection tanks. OK im thinking its a tank problem then! Ill go rewire it again, ive already done it once today though internally instead, i had chopped the suply wire messing with the engine mount!
6th Jul, 2004 at 05:52:18pm
sorry to be thick, but when speedfreaq's post mentiones the boost guage reasing maximum -20 vacumm, this is normal isnt it?
6th Jul, 2004 at 07:19:00pm
sorry to post agian but im completely stuck here. The connections are definately right, ive checked everyhting and completely redone the fuel pipes, the feed is definately the right way round on the regulator.
6th Jul, 2004 at 10:25:41pm
Has your distributor been moved? Once the plugs are wet they won't spark so it could be catching on just 1 or 2 cylinders. If you keep turning the engine over, eventually the cylinders will flood, the carb doesn't know the engine isn't running so just keeps putting fuel in!
6th Jul, 2004 at 10:37:41pm
yeah its definately running on all four. OK thats great about the fuel, It doesnt look like it, it just smells really strong of fuel on the dipstick. Ive taken everything off now and changed all the gaskets (carb ones) im going to put my other turbo on and the carb and manifolds back on tomorow and try again.
![]() 213 Posts Member #: 249 Senior Member |
6th Jul, 2004 at 10:43:56pm
the minus vacumm is normal on a turbo engine as far as im aware... my cosworth and skyline both ran at about -10/15 at idle....i would recheck every wire,cable and pipe....then reset ignition timing,plug gaps and check rotor arm and then double check everything again...it does sound electrical/ignition
Edited by mark4765 on 6th Jul, 2004. |
6th Jul, 2004 at 10:44:31pm
there was no chance the rotor arm got caught and cracked or something silly? I am sure you are capeable of putting the HT leads back in the same place they came from. Speedster turbo under construction |
6th Jul, 2004 at 10:52:12pm
oooh ill check that tomorow sparky, ill swap it with another rotor arm out of another electronic ignition, thanks for that!
6th Jul, 2004 at 10:59:39pm
not really anything to do with the starter except the starter is doing the turning instead of the engine. If the rotor arm is damaged it won't be sending the spark at the right time or may be sending just a weak spark which can't get through the fuel-soaked plugs.
6th Jul, 2004 at 11:01:20pm
sounds like mine, when i was trying, but i did not have the fuel prob.
6th Jul, 2004 at 11:04:52pm
ok excellent, that makes me feel better about the vacuum. The electrical side should be fine, its a new wiring loom in there. Ill recheck it though just incase tomorow. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
6th Jul, 2004 at 11:08:38pm
oh yeah that would be excellent if you fancy popping in!!! Ill be on wiht it first thing in the morning to get hte turbo back on and everything. Yeah im in keighley! Ill be working on the car 9am - 1pm, then not again until 5pm after work (have to fund the wasted oil costs!!!) Only bad thing is im about 2 miles out of keighley, its quite hard to find, i met iain in keighley as it was easier to explain how to get there, my post code is BD22 9BW
7th Jul, 2004 at 12:12:35am
I will try to make it, e-mail me your number so I can call you when I get lost! davefvl@btopenworld.com
7th Jul, 2004 at 03:38:11pm
feebleuk, I thought you had no friends who could drive??
what is it, 20/50 yeah? ill get the expensive castrol stuff thats good isnt it?
