Home > Show Us Yours! > My new Fiesta brakes
G13B
Member #: 1376
why exactly are sliding calipers crap? I can see that they maybe seem to flex more due to the design, but they have a good deal of pros to…no fluid ways running over the disk, easy service, cheap, big pads (don´t know if thats better than small ones…) they are about 2 kg including mounting bracket not that far off s calipers i guess…
Thanks for the kind words Nic, mucho appreciated!
It´s a suzuki swift engine, G13B variant
I'm guessing its a G13B.
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
I like the exhaust,
If the brakes work.......
Everyones got different preferances when it comes to braking and brake in different manners.
I know i dont like cars with servos. Theres no effort
Jay#2
Member #: 648
Northern Ireland (ex AUS)
The flex and potenial for siezing/uneven pad wear is a trade off for swept area. Plus all the M sport BMs (M3 M5 and lardy X5s) run twin piston sliding rather than the usual monoblock 4 pistons.
On 7th Nov, 2008 Nic said:
naeJ
m
On 23rd Jan, 2008 G13B said:
On 23rd Jan, 2008 gr4h4m said:
looks just like mine.. We did mine this time last year with a friend from the local mini club.. top job and much better than the drums I had fitted. We then created the how to vid..
The mini addicts vid?
had a little prob with the metro drive flange bolts, they have metric threads, i used the original 8,4 bolts but don´t know if they are up to the job? They are a bit shorter and have smaller head, is it possible to re tapp the disks?
cheers
//marcus
Yep we used the mini bolts... it was a mistake on the vid.. but we put an update on the miniaddicts web site. I must admit I never re-edited the vid.. I'm not sure we still have the original footage to edit it anymore...
IMO the brakes on my 10" are as good as the 8.4" setup on a 12" mini, not bad when you think you are loosing the extra torque arm effect.
They are cheaper that the Alloy options esp if you are upgrading from drums. The single sliding mech is good if you keep them serviced, just like any brakes really.
I would be interested to try the setup with the Yellow tag MC, as I'm using the single circuit bean can .70
G13B
Member #: 1376
I´m having 0.625 girling cylinder, single line system, was first using bean can on my S brakes, not so good…very hard pedal, 0.625 is loads better! Whats the size of the the yellow one?
Thanks for the vids, find them very useful - you guys should be on TV:)
//marcus
The vid idea was to make the how to's on my local clubs website a little easier.. (Miniaddicts) but the interest on you tube seem to have grown all over the globe, scary really.
The yellow tag is .75 to the front and .70 rear but its twin circuit hence why I have never changed. I friend was using a .625 on a 6 pot setup but it he found a better pedal with a .75 (He used a clutch MC as the original .75 single hasn't been available for ages) He had to mod the MC I think it was something to do with the return spring.
Edited by gr4h4m on 24th Jan, 2008.
G13B
Member #: 1376
Thanks for the info regarding tandem master, i was under the impression that if you downsize master cylinder bore you increase line pressure = more brake clamping force (but less fluid moved), please correct me if im wrong*happy*
A bit curious in how much fluid the single pot fiestas need compared to other calipers…
cheers
//marcus
When I looked into it... it also depends on cylinder size at both ends of the circuit.
I'm happy with the .75 but you do get a shock when you jump in from a modern servo car. Its all about feel which is personal.. he found that the 6 pots when smaller Sq area that the kad 4 pots he had on before. The .625 cylinder made the pedal too hard to get the car to slow down if I remember correctly...
Richie
Member #: 628
Vegard is a gaylord :)
On 24th Jan, 2008 Vegard said:
Sliding calipers are rubbish, end of story.
had these on mine and they worked better than the "S" items *wink*
EDIT: but you cant run 10" wellers or reverse rims *wink* trust me !!!
Edited by Richie on 2nd Feb, 2008.
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
Richie
Member #: 628
BTW if peeps have old fezzy callipers i can get new ones exchange for 35 quid each *wink* (this price was last year but dont think it would have gone up much)
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
