| Home > General Chat > 6000 rpm + | |||||||
8th Jul, 2004 at 09:09:06pm
Totally agree with minster.
62 Posts Member #: 198 Advanced Member |
8th Jul, 2004 at 09:14:32pm
Exactly, its all a compromise and finding what works best takes hours of practical tests, that why Visard spent years researching what works and what doesn't.
439 Posts Member #: 275 Senior Member bonie scotland |
8th Jul, 2004 at 10:38:34pm
so what do we recomend for a turbo, can we adapt things to fit. or remogage the house buy a turbo |
9th Jul, 2004 at 07:41:42am
follow tried and tested routes...
9th Jul, 2004 at 10:05:07am
Sadly Vizard's work is all very old and he didnt do very much work on turbo engines.
AlexF |
9th Jul, 2004 at 10:26:17am
didn't say he did, I'm just saying it takes time trying different things to find what works best. just used him as an example.
9th Jul, 2004 at 11:03:48am
NOt being funny here, but I worked with engine design and turbo selection... so I've read a fair few books. I am familiar with manifold or back pressure.
AlexF |
9th Jul, 2004 at 07:04:34pm
overlap reduces your CR? how? the effective compression ratio is affected by the closing of the inlet valve on the compression ratio. Yes you can use this to effectively lower or raise the effect CR.
9th Jul, 2004 at 07:23:29pm
"If you utilise a turbine housing with a larger area/radius ratio, in order to combat an increase in lag and reduction in response, its essential to decrease overlap"
10th Jul, 2004 at 08:45:28am
largeror smaller tubine, larger or smaller compresor, we still dont no what the the answer is, or do we, in the pursuit looking for more power, enjoyment????????? i dont want to spend my hard earned cash on hybryd turbo, so whats the answer, KISS ? keep it simple stupid |
10th Jul, 2004 at 09:19:25am
The answer depends on what you want... more power will always need a bigger turbo, a t3 flows more air for the same psi than a t2...
AlexF |
10th Jul, 2004 at 09:22:25am
So you are saying that a 60 trim T2 does not not flow more air than a 40 trim T3?
10th Jul, 2004 at 09:48:28am
I cant find my t2 comp maps...
AlexF |
10th Jul, 2004 at 10:28:35pm
Don't worry about it, was only trying to promote a response (it was the 1664 typing not me!!!)
10th Jul, 2004 at 10:56:36pm
my understanding of makeing the engine to rev, is suficent air, corect fuel mixture. proper ignition. no valve bounce, as i have a decent cylinder head, phase 2 cam, valve springs good enough 8200, std turbo distributor good nick, but is the turbo holding it back |
11th Jul, 2004 at 12:31:16pm
No the turbo will not limit the engines power range. Just like a naturally aspirated engine to raise the power you need to improve the breathing of the engine, I.e. cams and head work.
11th Jul, 2004 at 12:34:38pm
raise the maximum power engine speed should i say! |
11th Jul, 2004 at 03:53:56pm
so can we say were making progress, ? |
11th Jul, 2004 at 04:12:48pm
is a standard turbo distributor ok for high revs high bost |
11th Jul, 2004 at 05:04:46pm
Yeah, you'd have to limit the maximum advance depending on how much boost you run, you require roughly 1 degree less advance for every 1 psi more boost.
11th Jul, 2004 at 06:19:28pm
going have to think about this a bit more, cheers minster |
11th Jul, 2004 at 07:12:36pm
The distributer is easy to modify, I think in order to raise the useful power band though you'd need quite a sporty cam. As per a NA engine |
12th Jul, 2004 at 09:02:31am
I'm not overly convinced you need 'as much' cam for a given max power rpm (compared to a nat-asp) though...
12th Jul, 2004 at 09:39:47am
LOL wanna go halves on one Dave?
AlexF |
12th Jul, 2004 at 11:01:40am
You will need the same spec head cams etc as you would for a naturally aspirated (within reason!) As max torque is reached when the head etc becomes a restriction, with or without boost.
