Home > General Chat > MED
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Go for small independants with a good reputation. :)
On 19th Jan, 2010 wil_h said:
maccamcvey
Member #: 6673
Worral Sheffield
i need to get the block and crank ect sorted first, would you go for a kit from somewhere like morspeed or med?
Or dose anyone know of someone small and reputable, somewhere near manchester?
i am planning on +.020 bore, face, acid dip, 11 stud, 5/16 box bolts and C.M.S. on the block, re ground, ni-temp and polished crank and balanced rods.
Have i missed anything important? or equally going a bit far?
Thanks guys
dont really need the 5/16 block bolts, just get a set of qauality ones from turbodave on here *wink*
aprt from that sounds good,
maccamcvey
Member #: 6673
Worral Sheffield
all ready have them :( and drilled my box so a bit late, oh well
I think i should start my own thread kinda hijacked this one sorry
SumpNut
Member #: 28
Wow, what a blast from the past.
I'm really suprised I said this as the head MED did for me lasted 50 miles before blowing into the water jacket. This led to destroying the bore and piston rings in number three and the contaminated oil ruined my turbocharger and mains.
I must admit MED did sort me out a replacement head and large discount off new pistons/machine work - but I still ended up out of pocket.
Why not try TurboPhill or BenRoss for head porting.
On 13th Jul, 2004 SumpNut said:
I use a MED head - they high boost jobby. The quality of the work seems to be good (in my opinion) And no faults - it has been independently pressure tested etc by my local maching shop - they recon its the dogs b*****s
Mr Joshua
Member #: 1954
Luton Bedfordshire
Blow the dust off of this one cough!
Own the day
giallofly
Member #: 164
The Stig..
Newport Pagnell
Give turbo phil a shot if you are after a new head...
They are pretty good and a proven part of a race winning package.
JF.
says it all Jon well done to you both*happy*
maccamcvey
Member #: 6673
Worral Sheffield
Thanks guys much appreciated
