Home > Help Needed / General Tech Chat > Intercooler!!
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
On 13th Apr, 2008 Nic said:
have a look at what carls clubman used to look like, i remember that being a very tidy set up before he became a traitor to the push rods
*laughing*
Ive seen a cooler where you were thinking about mounting it on here. Id try it and see if it is efficient enough for your needs.
Edited by Jordan on 13th Apr, 2008.
If Matty can fit it into a round nose then you must be able to fit it into a Clubby!
It's all about tril and error. Make a cardboard mockup of some of the suggested intercoolers and try them in a few positions.
Joe, It's going to fit a treat. I've been working hard on the brakes this weekend. It shoud be in by next weekend though.
Ah! good good.
was a little concerned with not having your car there to check it against
And you think you have no room for an intercooler!
LMAO *laughing* *laughing*
t=1208156476
pristic
Member #: 1774
Sydney AUS
Im running a 300zx IC on mine... sits behind a clubby grille neatly. Could still run an oil cooler on the right or bottom if you wanted to (I have a heater core on the right for mine)
1132cc Turbo ~120 bananas ATW - Fun Fun Fun
pristic
Member #: 1774
Sydney AUS
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Well theres and option, you could always go back to a side mount rad and juggle things around?
On 7th Nov, 2008 Nic said:
naeJ
m
My initial thought was to mount it flat on the LHS of the engine bay and have a scoop on the bonnet. The heat soak wouldn't be too bad over that side of the engine.
However, I refrained from my suggestion as a scoop is not a nice thing to have, especially on one side of the bonnet.
But then I picked up this months copy of Minimag, and in there is Miniwilliams' car. Look at how his IC is mounted, could be the solution. Actually, thinking about it, it might be the oil cooler, but the principle is the same, Matt?
