Home > Help Needed / General Tech Chat > Trying to find thin fan?
On 2nd Jun, 2008 mini13 said:
i'm assuming matty will have that.
Not sure which ones your on about? Are you on about the ones for £40 as there are loads of them?
Iain definitely need one. Its fine when your driving along it cools quite quickly but standing still its heats up quickly. The good thing about having the leccy fan is that I also have a leccy water pump so I can cool the engine down quick between runs at avon. *wink* (not that you ever manage to get 2 runs in within the hour). Lol
for some reason i can leave mine sat for a good 15mins etc without any temp issues. must have ended up with a good casting i guess.
all seems to be done to luck a lot of the time!
mine gets up to about 90 when stood but as i said after a while, that sort of temp doesnt bother me at all.
It used to be ok on the other block. Ive now also got a water cooled turbo and 80 degree thermostat so its putting a little more strain on the cooling system too! *oh well*
maybe if you get the leccy pump sorted it might help at low rpms?
just thinking of other things other than a fan if your tight on space.
Righty, decided to go for the spal one. Im just going to have to have to space my rad out further! *oh well* Hopefully it won't look too bad!
