Home > Help Needed / General Tech Chat > toyota coversion problem..... please help if poss lol FIXED IT
I would check your power cable to the pump - is it getting hot?
The pump is now having to draw about ten times the current that it used to. If the cable feeding it is too small it will get hot, you will get a volt drop and the pump will slow down.
Carl
Member #: 95
liverpool-on-sea
looking at one of these pumps but how do you work out which one you need
http://www.demon-tweeks.co.uk/products/sea...e=all&x=30&y=13
I've got this spare, if it's any good for you...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...:EOIBSA:GB:1123
I would think something like this would do the job. Do you know what pressure your injectors are sized to work at?
http://www.demon-tweeks.co.uk/products/Pro...&pcode=FSEFP601
Carl
Member #: 95
liverpool-on-sea
thanks gary, im trying to sort one this weekend mate. if i dont ill get back to you.
matty not got a clue, if i get a higher one with a higher flow rate than i need will it still work ok?
Can't see why not as long as the FPR could cope and its not waaaayy out? *oh well*
I would think something around the 3Bar 150L/Hr would be fine. Looking at some of the pumps on ebay they have pumps flowing 255L/Hr and say they're good for 500bhp (@80psi), listed for supra,starlets etc...They also mentioned the standard pump flows 132L/Hr (@80psi) so may be worth checking what the standard pressure is?
look on ebay for the pump, theres a few people on there selling them cheaper
http://cgi.ebay.co.uk/NOVA-ASTRA-MANTA-GTE...p3286.m20.l1116 ?
Carl
Member #: 95
liverpool-on-sea
yep you must have found the same add as me matty. looked everywhere and cant find any specs on standard pump only that add you mentioned, hmmm rung round few scrappys as well but non have anything in with external pump. ill keep searching thanks for all the help people.
If you want to buy new, the Walbros are good value. GSS 392 is the "bigger" version, in-line.
But pretty much any Bosch efi pump will be more than adequate.
Carl
Member #: 95
liverpool-on-sea
just found this which says the auu 1649 pump is 12v/3bar/160lph and the ebay one ive ordered is a replacement for that so it should be ok, fingures crossed
http://www.sparts.cn/catalog/FP-2.pdf
Edited by Carl on 4th Jul, 2008.
Carl
Member #: 95
liverpool-on-sea
sorted wahoo. avonpark here we come.
right so my new replcement metty turbo pump arrived sat morning, took old pump off and noticed its a sytec injection pump so surely should be upto job, so must be faulty. fitted me new pump and within 5 mins was making same noise as old one, Doh! checked all fuel lines again- still bad. removed fuel filter and retryed-still bad. hmm pissing me off by now. anyway i decided to rip the tank out and have a nosey inside. all looks good so i decided to knock the little guaze off the pick up pipe, and guess what it works fine know so i left it off not ideal but will get me to avon. done about 25 miles tonite and touch wood it went fine.
thabks for the help people.
p.s i fitted me old pump coz its better than me ebay special.
T3Tone
Member #: 252
Sunny suffolk
Excellent news mate, glad you got it sorted. Think TD may be having words with you though *wink*
-MINI CLUBMAN 1380 TURBO-
Carl - I honestly suspect you'll run into issues with the stock pump on an efi turbo.
If you can stretch to a different (but a quality, not nangbingchang shite) pump, then do so.
That gauze in the bottom of the tank is a total PITA - sometimes it's not a problem, other times it's always the problem.
So...
How does it drive?????
Carl
Member #: 95
liverpool-on-sea
when i have the money or i wanna up the boost, which ever comes 1st i will be upgrading the pump, right know im just glad its running. was thinking of fitting a mpi tank with uprated pump.
Carl
Member #: 95
liverpool-on-sea
On 7th Jul, 2008 theoneeyedlizard said:
So...
not really given it the full beans, suspensions all over the place but upto now im well happy, defo doesnt feel as quick as me a series but is a totally different beast, nice smooth power delivery, cant wait till avon going to be interesting to see what it runs, it totally stock except for decat pipe.
attempting to take it to work tomorrow to set suspenion up then ill give it a booting lol.
Glad you got it sorted mate! Will be good to see it at Avon.
