| Home > Help Needed / General Tech Chat > 2 Fuel Filter | |||||||
13th Sep, 2008 at 11:32:24am
Must be lucky then, I,ve been using plastic filters ever since I went turbo BUT I always put the filter before the pump to save any crap going through the pump.I change them twice a year,total cost about £2. |
13th Sep, 2008 at 11:39:46am
Put them before the pump and they can never see any pressure so no problem (just like on my lawnmower!) but the setup here uses a high pressure pump (one that is usually used for fuel injection) with the filter after it and before the regulator :) Schrödinger's cat - so which one am I ??? |
13th Sep, 2008 at 03:27:59pm
Thank you - I do understand,but where is the need for a filter after the pump if you have filtered the fuel before it gets there ?. |
13th Sep, 2008 at 04:03:52pm
cause when the pump fails itll send crap down the line :) all you really need before the pump is some gause. and a good injection pressure rated filter after :) turbo 16v k-series 11.9@118.9 :)
13th Sep, 2008 at 05:00:29pm
As Evolution says...
13th Sep, 2008 at 06:15:14pm
Thank you for the clarification -I have a gauze filter in the tank to filter out dead mice and birds etc and the aforementioned plastic filter after that - -I do wear belt and braces.
13th Sep, 2008 at 07:49:38pm
All the fittings on my system are bolted aeroquip so im fine in that department thanks.
Own the day
13th Sep, 2008 at 08:00:07pm
On 13th Sep, 2008 tadge44 said: You are lucky because what you have effectively done is introduce a restriction before the pump. If the restriction is sufficent enough it can cause the pump (For example the Metro Turbo item) to cavitate and stop pumping.
Must be lucky then, I,ve been using plastic filters ever since I went turbo BUT I always put the filter before the pump to save any crap going through the pump.I change them twice a year,total cost about £2. If you get the chance get under a Maestro 2L efi or Metro Turbo and look at the size of the outlet from the tank. If the pipe I/D feeding into your pump is smaller than the pump inlet I/D you have a potential problem that can be very hard to diagnose. Own the day
13th Sep, 2008 at 08:23:26pm
I think we are in violant agreement !!!!
15th Sep, 2008 at 10:05:16am
Sorry, i used these kind of unions http://www.minispares.com/Product.aspx?pid=38282 |
