Home > General Chat > Weird running Problem
Im still sticking with choke seals. Would explein the over fueling and poor running. If its heat related its got to be something expanding e.g. valves going tight in guides or valves clearances tightening up or fueling. A cold engine will run on a very rich mixture where as a hot engine won't.
What colour are the plugs?
EDIT: If its isn't the seals...it could be running VERY lean and occasionally burning on the exhaust stroke due to having wasted spark?
Edited by matty on 22nd Mar, 2009.
ministef1
Member #: 1791
Cranleigh, surrey
When you mean choke seals would you be implying i use a choke?
Plugs are a normal colour, not sooty and not to greyish! I've ordered a mpi coil pack and some new plugs.
See if that cure's it first.
"Cars are a lifetime of pain"
Didn't Nic have a similar problem that turned out to be a sticking valve?
It dosen't sound like a coil problem to me.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
It could easily be a coil problem, I have had troubles like these with coils in the past.
That said, there are numerous other possibilities, that have been mentioned
ministef1
Member #: 1791
Cranleigh, surrey
well I'll try the cheap option first.....then i'll go down the head of pain in the arse route if my problems arn't solved......
Ill let you know how i get on when the coil pack turns up.
DD_Racing
Member #: 3013
Epsom Surrey
did u order a msd coil???
ministef1
Member #: 1791
Cranleigh, surrey
No i've got a friend with one, just going to pinch his see if it works.....then i might invest? I take it its the ford replacement one i need DD?
DD_Racing
Member #: 3013
Epsom Surrey
well any msd that will plug into yours but i think they do areplacment for the ford type
that what plug youve got then??
ministef1
Member #: 1791
Cranleigh, surrey
the one for the rover and ford are different. So mines the rover one, its simple enought to change. Maybe after a few other bits though. if it is that after all still waiting on a coil pack!
DD_Racing
Member #: 3013
Epsom Surrey
i did have a thourght that maybe it could be fueling cos ive had this problem on my brothers vauxhall like backfiring and missing bad cos it was so rich but that was webbers and the main circuit was way out
but then this is one of those problems where youve got to go through the list and eliminate every problem
ministef1
Member #: 1791
Cranleigh, surrey
i know very annoying, But i should have my coil pack and other bits waiting for me when i get back from work.
ministef1
Member #: 1791
Cranleigh, surrey
I've just thought of something else i did when i put it back on the road, about 10 miles ago, I put a bottle of millers cvl in, probably only about 10 liters of fuel in there? would this be a factor?
stef
did you put the whole bottle in?
ministef1
Member #: 1791
Cranleigh, surrey
yes, but realising this i went and put another 10 liters f fuel in!
It wouldn't make that much difference would it?
what is the proper dose?
ministef1
Member #: 1791
Cranleigh, surrey
bottle per 20l, so its not that bad.....
probably wouldnt make a difference.
how old was the petrol?
ministef1
Member #: 1791
Cranleigh, surrey
well a little update, managed about 20 miles constent running on sunday then just as i was heading up the hill to brooklands and hit traffic it started coughing and backfiring from 1500 rpm and just couldn't drive it.
So I got out pulled over, let it cool down a bit (while pushing it up the hill) then it started and ran fine.
This is getting to be more confusing than anything?
ANY BODY GOT ANY MORE IDEAS???
stef
Faulty pickup on crank pulley ?
do you have any way of watching the map/any widebands while this is happening?
if not, get down to your freindly mot station while it is happeneing and see if they will stick it on the gas analyzer while its missfiring.
this will tell you whether its an ignition or fueling missfire! easy peasy!!
then....you can get the resistance values etc etc for the ignition components and check them all over.
no splashing out on bits that you dont need.....instead you can send that money my way.
ministef1
Member #: 1791
Cranleigh, surrey
Ok little update, i played around with this on saturday and have come to the conclusion, i still don't know what it is. It now seems to have a steady misfire on tick over, not sure if its still doing the other symptons when hot, but i'm sure the two are related.
So far i have done this.....
*Replaced Coil Pack
*Replaced Plugs
*check for spark on all 4 plugs with a spark plug checker thing!
*check the crank sensor (was wet inside the connector, so cleaned and dried and put back togeather)
Although i had the plugs out the two nearest the rad where brownish in colour, and the 2 nearest the clutch where black and slightly wet? any ideas?
errr starting to get annoyed now.
Read this thread. http://www.turbominis.co.uk/forums/index.p...tid=217682&fr=0
Mr Joshua
Member #: 1954
Luton Bedfordshire
Leads breaking down under heat
Own the day
ministef1
Member #: 1791
Cranleigh, surrey
read that thread really interesting, I did a compression test last night and mine were as follow,
1 = 130psi
2 = 130psi
3 = 126psi
4 = 130 psi
Also checked the valve clearences and they seem to be different, although my thought now is with leads, so i'm going to have to bight the bullet and buy some. rubbish!
Mr Joshua
Member #: 1954
Luton Bedfordshire
In a turbo as you know heat is a real issue if your leads are old then start there. Cheapest option first.
Own the day
