| Home > Technical Chat > Supercharger theory | |||||||
869 Posts Member #: 2443 Post Whore Cheshire |
26th Mar, 2009 at 10:32:04pm
The way i see it is that by simple thermodynamics the temperature of air increases when under compression.
Edited by Andy500 on 26th Mar, 2009. |
26th Mar, 2009 at 10:38:20pm
Thinking about it, i guess the fuel would have an overall cooling effect to intake temperatures. As the fuel would absorb heat energy which would be converted to pressure.....something along the lines of p1/p2=v1/v2=t1/t2 |
26th Mar, 2009 at 11:57:19pm
Andy, you touched on it in the post above.
Edited by Sprocket on 27th Mar, 2009. On 26th Oct, 2004 TurboDave16v said:
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
27th Mar, 2009 at 12:08:23am
There is an element of Le Chatelier's principle at work.
Bugger off, I'm getting there. |
27th Mar, 2009 at 12:26:16am
Ah, just had a thought.
![]() 6753 Posts Member #: 828 Post Whore uranus |
27th Mar, 2009 at 08:20:11am
little bit from wiki
27th Mar, 2009 at 08:22:59am
Interesting stuff. I don't understand the science behind it, but my (very simple) understanding of this is that the air that is fed into the carb and then of through the suck through s/c with the fuel needs to be as cool as possible before getting mixed with the fuel?
27th Mar, 2009 at 08:50:02am
A more active discuaaion than I was expecting. Still not convinced I now know the answer.
326 Posts Member #: 1323 Senior Member |
27th Mar, 2009 at 04:36:28pm
On 26th Mar, 2009 robert said:
so if its trapped between the supercharger and the inlet valves ,boost will rise and the charge will get cooler ? wil ,heres another link http://www.thedrivenman.com/AJ6/superchargers.html heres a bit from it PRESENT-DAY SUPERCHARGING - It seems even now to be a little recognised fact that adding just a proportion of the fuel before the supercharger is a very effective method of lowering charge temperature by evaporation during compression, as well as being a good method of mixture preparation. There is an efficiency gain here which is not immediately obvious. Cooling the charge as it is compressed is of more benefit than any form of cooling after the event (by an inter-cooler for instance, although further charge-cooling may still be beneficial) because the work consumed by the compressor will be reduced. Water or water/methanol injection can be used for the same purpose. This important advantage is denied to the Roots device because of its lack of internal compression. Stanley Hooker estimated that adding fuel ahead of the supercharger dropped the air temperature by 25 degrees C on the Merlin, enabling it to consistently outperform the larger and supposedly more advanced German engines with direct fuel injection into the cylinders. Fuel has to be added anyway so why not add it where it will do most good? ^^^^^^ I believe this is a myth The Spitfire couldn't outperform the ME109 Apparently they've done performance tests to dispel this The difference was that the 109's only had a few minutes combat fuel before they had to turn for home The benefit of the Spitfire was that it was very nice to fly and very forgiving , ideal for inadequately trained pilots ! sorry, bit of topic . |
27th Mar, 2009 at 04:50:18pm
In my opinion, wherever there is a pressure drop between the rotors and the carb, you want to prevent heat ingress. (Part throttle settings). You also want to maximise heat loss between the blower and the head.
27th Mar, 2009 at 06:02:11pm
so if its trapped between the supercharger and the inlet valves ,boost will rise and the charge will get cooler ? wil ,heres another link http://www.thedrivenman.com/AJ6/superchargers.html heres a bit from it PRESENT-DAY SUPERCHARGING - It seems even now to be a little recognised fact that adding just a proportion of the fuel before the supercharger is a very effective method of lowering charge temperature by evaporation during compression, as well as being a good method of mixture preparation. There is an efficiency gain here which is not immediately obvious. Cooling the charge as it is compressed is of more benefit than any form of cooling after the event (by an inter-cooler for instance, although further charge-cooling may still be beneficial) because the work consumed by the compressor will be reduced. Water or water/methanol injection can be used for the same purpose. This important advantage is denied to the Roots device because of its lack of internal compression. Stanley Hooker estimated that adding fuel ahead of the supercharger dropped the air temperature by 25 degrees C on the Merlin, enabling it to consistently outperform the larger and supposedly more advanced German engines with direct fuel injection into the cylinders. Fuel has to be added anyway so why not add it where it will do most good? ^^^^^^ I believe this is a myth The Spitfire couldn't outperform the ME109 Apparently they've done performance tests to dispel this The difference was that the 109's only had a few minutes combat fuel before they had to turn for home The benefit of the Spitfire was that it was very nice to fly and very forgiving , ideal for inadequately trained pilots ! sorry, bit of topic . I used to know a real Spitfire pilot, you could sit and listen to his stories for hours and hours. Very nice bloke:) On 26th Oct, 2004 TurboDave16v said:
27th Mar, 2009 at 06:08:01pm
I like te look of those G Lader jobs, they look the ticket, but can you get one small enough On 26th Oct, 2004 TurboDave16v said:
27th Mar, 2009 at 06:13:15pm
the g laders are a bit fraggle though, seem quite pricey too. On 28th Aug, 2011 Kean said:
667 Posts Member #: 1376 Post Whore clock tower with a sniper rifle |
27th Mar, 2009 at 08:19:44pm
get a rotrex, 10 times better:)
internationally known as "big" swede |
27th Mar, 2009 at 08:21:13pm
The G40 Polo used a G-ladder, and that was 1300 iirc. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
1050 Posts Member #: 764 Post Whore Staffordshire |
27th Mar, 2009 at 10:45:06pm
On 26th Mar, 2009 Nic said:
What the fuck is going on in here????????? i have no idea either... but it does leave me thinking why i prefer turbomini's to "other forums" :) |
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
27th Mar, 2009 at 11:46:09pm
28th Mar, 2009 at 06:40:43pm
I used a Ladder to get in my loft yesterday..
On 27th Mar, 2009 wil_h said:
The G40 Polo used a G-ladder, and that was 1300 iirc. I run a supercharger and I don't care the TB is on the wrong side.
28th Mar, 2009 at 06:44:04pm
fat birds use a g ladder to get their knickers on! On 28th Aug, 2011 Kean said:
28th Mar, 2009 at 06:47:01pm
