Home > Help Needed / General Tech Chat > subframe modification to lower the car (tower mod)
Scruffy
Member #: 328
Seaford Rise, South Australia
Yes Slater! Don't know if I would want to do this though?
On 5th Sep, 2011 Vegard said:
Ben H
Member #: 184
Melton Mowbray, Pie Country
I think that ours dosen't bind because we run a little -ve camber. This helps out the top ball joint a little. Mind you it has to get pretty low before they do bind.
http://www.twin-turbo.co.uk
I got over it by making a new subframe that puts the top and bottom arms 1" higher than a standard subframe
Paul
lockfast
Member #: 2775
Aberdeen
Any pics Paul? Did you completly make a subframe or did you modify an existing one?
Yes I have pics, Yes I made an all new one
Paul
lockfast
Member #: 2775
Aberdeen
Can we see them. Please. Not that I plan to bulib one. I just love to see what other people do. Lets call it insperation!
OK, this is a 5 year old design, but didnt know if it would work so never fitted it. The Don has proved it does work
Its made from T45 CDS and saved 10 kg over my severely lightened standard subframe.
The 3 main reasons for it are;
1, Its stiffer to stop the front of the car accellerating quicker than the rest.
2, Top balljoint angle is improved.
3, Top arm design should help to stop some of the rearward weight transfer.
Paul
Ben H
Member #: 184
I looked at doing the same, but modifing an existing subframe. I haven't done it though.
