| Home > Help Needed / General Tech Chat > Megajolt Setup | |||||||
21st Apr, 2009 at 02:30:54am
Edited by Turbo Tel on 21st Apr, 2009. website:- http://www.terryhunt.co.uk
329 Posts Member #: 3193 Senior Member Torbay, Devon |
24th Apr, 2009 at 11:27:15am
24th Apr, 2009 at 12:39:16pm
have you tried changing the connections on the vr round, checked your plugs have not broken down. and make sure you have the ht leads the right way around Edited by philc on 24th Apr, 2009. |
24th Apr, 2009 at 01:40:17pm
Hi
![]() 902 Posts Member #: 111 Post Whore Loughborough |
24th Apr, 2009 at 01:42:14pm
Is your crank sensor mounted 90deg from the missing tooth at tdc? If not any timming on the mj will be wrong. |
1050 Posts Member #: 764 Post Whore Staffordshire |
24th Apr, 2009 at 02:56:26pm
i have a map that should run that spec, but its for map... Is there a way to translate? |
24th Apr, 2009 at 04:08:03pm
On 24th Apr, 2009 Anton said:
i have a map that should run that spec, but its for map... Is there a way to translate? that map will be fine for TPS in the first instance, then he will have to change his values from 0-100% |
24th Apr, 2009 at 04:10:03pm
perhaps get some pics on here for people to see what you have |
24th Apr, 2009 at 04:16:56pm
On 24th Apr, 2009 Alex1340 said:
Is your crank sensor mounted 90deg from the missing tooth at tdc? If not any timming on the mj will be wrong. Just to double check this am i right to say, set number 1, (closest to rad) at TDC, then put the missing tooth straight up. The sensor is set at 9 o'clock. Cheers Jon |
24th Apr, 2009 at 04:24:09pm
and as a guide each tooth is 10 degrees |
