Home > Help Needed / General Tech Chat > Crank Endfloat
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
I think you must be able to.
As someone mentioned recently you can measure your crank endfloat by getting a DTI gauge on the flywheel through through the starter housing and levering the crank pulley.
I always use the thinnest smear of oil both on the back, and the front of my shells when plastiguaging. Fact is, oil alwayus gets behind the shells / thrusts, so i measure mine in what i feel is 'most representative' of what it will be in service.
madcatminis
Member #: 5327
Dudley, West mids
My crank is in now. All main caps torqued up. Spins beautiful and has 2 thou endfloat. I'm a happy bunny! *Clapping*
result
Oli
Member #: 1910
Wilts
Good Stuff.
