Home > Technical Chat > raised port heads
Mr Joshua
Member #: 1954
Luton Bedfordshire
I am currebtly having a head welded after breaking through into a water way during porting, could you not have the oprn water ways welded up before you fir the sleeve thereby iliminating sealing issues? Or is this already done?
Own the day
On 23rd Jun, 2009 ministef1 said:
is that a crack through the spark plug hole?
yes stef, damages in three place, two between valves and the spart plug hole which is why it was retired from nitrous , none reach water though so will still work if needed,
carl.
Owen
Member #: 6496
Somerset
On 22nd Jun, 2009 Turbo Phil said:
Yes, that's been done. I started a thread a while ago about it. Search for "downdraught head".
I plugged it into the search but it didn't return any results, have you got a link for it? Sounds like an interesting read! Cheers!
On 9th Feb, 2010 joeybaby83 said:
yep, ball in a tube affair
here you go, was a bit tricy to find.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=275986
Owen
Member #: 6496
Somerset
Cheers dude! *happy*
