| Home > General Chat > Brake cleaner is REALLY nasty stuff... | |||||||
123 Posts Member #: 1234 Advanced Member Chester |
3rd Aug, 2009 at 11:19:03am
I used to work for a company who makes Brake Cleaner. From my memory Chlorinated solvents used in brake cleaner have been banned in the UK (and Europe) for some time, but not in the USA.
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
3rd Aug, 2009 at 11:55:48am
On 3rd Aug, 2009 nbooth660 said:
Nothing nasty, good solvency power and some have a non flammable propellant so you can't even blow yourself up. Nick. depressing isnt it!! What is the world comming to!!!
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
5th Aug, 2009 at 03:24:06pm
Also, don't mix hypochlorate and peroxide bleaches....unless you want to make loads of oxygen/chlorine gases!
Bugger off, I'm getting there. |
84 Posts Member #: 2404 Advanced Member Braintree, Essex |
5th Aug, 2009 at 08:59:09pm
I don't know how you would get HF when Teflon, which is PTFE, decomposes, as there is no hydrogen in it. Anyway, PTFE is about the most stable organic compound there is, it doesn't even begin to soften until nearly 400 deg C so no need to worry too much about your feet rotting away! Oh, and that should be hypochlorite, by the way...:)
Geoff |
365 Posts Member #: 1211 Senior Member Working up the BHP ladder. |
5th Aug, 2009 at 09:42:39pm
Thats scary shit.............! |
6th Aug, 2009 at 12:37:26am
I've suffered minor phosgene poisoning in my early working life, it was a hazard of the job. Perhaos that is the reason why I suffer with catarrh and tend to clear my throat alot. CFCs decompose with high heat producing phosgene. Compressor motor burn outs also produced this phosgene, but there was also the added bonus of Hydrogen chloride acids created from the coctail of CFC and hydrocarbon oils decomposing. If you managed to get any contaminated oil on your hands you could feel it 'tingle' and you would after a couple of days start to loose a layer of skin. On 26th Oct, 2004 TurboDave16v said:
6th Aug, 2009 at 12:39:12am
On 5th Aug, 2009 h4887 said:
I don't know how you would get HF when Teflon, which is PTFE, decomposes, as there is no hydrogen in it. Anyway, PTFE is about the most stable organic compound there is, it doesn't even begin to soften until nearly 400 deg C so no need to worry too much about your feet rotting away! Oh, and that should be hypochlorite, by the way...:) Geoff Refrigerant R134a eats PTFE for breakfast well ok it might take 6 months, but it turns it to putty.
6th Aug, 2009 at 12:47:32am
On 5th Aug, 2009 Hedgemonkey said:
Also, don't mix hypochlorate and peroxide bleaches....unless you want to make loads of oxygen/chlorine gases! The really really nasty one is HF produced when teflon rubbers decompose. You can find this in your boots and gaiters. Get it on you and you could be looking at bones turning to powder, sores that don't heal and possibly amputation! Really really horrible stuff. I think perhaps the nastiest of all chemicals. I thought the real nasties were PCBs http://en.wikipedia.org/wiki/Polychlorinated_biphenyl which are produced when certain rubber and electronic components decomposed in a fire On 26th Oct, 2004 TurboDave16v said:
1050 Posts Member #: 764 Post Whore Staffordshire |
6th Aug, 2009 at 10:38:16am
PCB's are nasty shit, used to recover is from old telecoms equipment a few years ago, cost a forune to dispose of.
Edited by Anton on 6th Aug, 2009. |
7th Aug, 2009 at 04:43:00pm
Hypochlorite....yep. Confusing with perchlorate...that I've been mucking around with recently! I get your comment about PTFE being mega stable. Odd how the HF warning is given if it is so stable.... There will be an oxidation of the molecule and then a reaction with water.... under what circumstances, I have no idea....that's assuming it happens, which the formation of CO2 and HF would be thermodynamically favourable (without resorting to a book). Bugger off, I'm getting there. |
72 Posts Member #: 6792 Advanced Member |
2nd Oct, 2009 at 11:06:24am
On 6th Aug, 2009 Anton said:
Although cotten braided cable was/is worse. (in terms of electronics disposal) Do you mean cotten braided cables are hazardous or just a pain to dispose of? |
2nd Oct, 2009 at 11:14:31am
MOWOG! Isn't that the name of the gorilla that used to over tighten crank pulleys on morris engines in the factory? If something is worth doing, it's worth doing half of. |
![]() 460 Posts Member #: 843 Senior Member Stoke-on-Trent. Duck. |
2nd Oct, 2009 at 07:55:12pm
Following several posts on Hydrofluoric acid, you'll notice at the start of the Wiki article it mentions "used to dissolve glass". A "good citizen" post here to let y'all know that vandals are using HF to 'tag' windows on public transport - if glass looks etched don't sit near it!
Edited by Pottsy on 2nd Oct, 2009. |
2nd Oct, 2009 at 11:55:06pm
the brake cleaner from frost smells delicious, im tempted to spray it on toast "Turbo's make torque, and torque makes fun"
13th Mar, 2011 at 10:31:04pm
Resurecting this topic since I have been researching WW1, and cam across this extract from wikipedia
Chlorinated compounds used to remove oils from metals, such as brake cleaner, are converted to phosgene by the UV rays of arc welding processes.
http://en.wikipedia.org/wiki/Phosgene. Edited by Sprocket on 13th Mar, 2011. On 26th Oct, 2004 TurboDave16v said:
13th Mar, 2011 at 10:35:59pm
Fuck!
13th Mar, 2011 at 10:41:31pm
that is nasty stuff Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
13th Mar, 2011 at 11:11:30pm
Bloody he'll, a good heads up! I used to use the stuff alot. On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
14th Mar, 2011 at 09:46:06pm
I'll have to remind myself to check the can of brake cleaner I've got, definately not using on stuff to be welded. The stuff stings to high hell if it rebounds off something and ends up spraying in your eye, plenty of pressure in those cans On 26th Jan, 2012 Tom Fenton said:
1083 Posts Member #: 8932 Post Whore |
14th Mar, 2011 at 10:02:44pm
blimey that makes you think twice, some of the shit i've inhaled working on the car, like paint burning while welding and stuff like that. sounds like our brake cleaner is fairly safe here. |
15th Mar, 2011 at 12:03:08pm
Also, don't mix hypochlorate and peroxide bleaches....unless you want to make loads of oxygen/chlorine gases! The really really nasty one is HF produced when teflon rubbers decompose. You can find this in your boots and gaiters. Get it on you and you could be looking at bones turning to powder, sores that don't heal and possibly amputation! Really really horrible stuff. I think perhaps the nastiest of all chemicals. I thought the real nasties were PCBs http://en.wikipedia.org/wiki/Polychlorinated_biphenyl which are produced when certain rubber and electronic components decomposed in a fire On 7th Nov, 2011 apbellamy said:
