Home > Help Needed / General Tech Chat > beam rear axle
You're right Vegard, my rear wheel does lift WAY too much. This, as I see it, is due to a number of factors. Namely: Front to soft, tyre pressures to low and the rear anti-roll bar.
However, if I manage to 'fix' the problem over the winter it will still ultimately lift the inside rear wheel. There's no way of getting away from it with a front-wheel drive front engined car. Even if you ocould keep it on the ground there would be so little weight on it it may as well be off the ground.
So is my suspension set-up faulty?? well yes and no. Yes it shouldn't lift that much, but no, because even with a beem axle the inside rear will still lift (or even if not lift, still be doing bugger all).
If you watch the British Touring Cars they all lift a rear wheel, and they wouldn't if it was better that they didn't wouldn't you say????
Wil
yes, I agree in the last statement, but look at Miglias. We alla gree that these are the fastest standardish Minis around, and they use all standard suspension bits. But, they don't lift much if at all... I know they use the yellow donuts at the front which are VERY hard, and make use of the tyres as "springs" as well..
I'm NOT looking forward to getting my own race mini right in the suspension dempartment. Too many factors me thinks :)
Hedgemonkey
Member #: 360
Front antiroll bar? I would consider what the opposite wheel is doing and look at how that behaves relative firstly to the adjacent wheel and then the opposite. Stiffening the wheels relaitive to themselves/axle pairs has the first effect of minimising lateral roll and the secondary effect of lowering the opposite wheel (diagonally).
I get loads of rear wheel lift, I could get it to corner flatter with a front bar but I don't think there are tyres up to the job, not to increase understeer. Besides, if you need more grip for the road using 032R's and an RARB as well as having it properly set up, you are probably not going to have your license very long.
Besides, I suppose it will just wear the diagonally opposite tyre (to the one lifting) out quicker with a FARB fitted
Edited by Hedgemonkey on 28th Dec, 2004.
