| Home > Help Needed / General Tech Chat > Megajolt V3 Software | |||||||
7th Apr, 2011 at 07:25:32pm
sorry to post on an old thread, but i have a v3 megajolt and it doesnt have the setting where you can offset the entire map. Can i get it to do this without +1 or -1 on my entire map?
7th Apr, 2011 at 08:19:16pm
what do you mean by offset?
7th Apr, 2011 at 09:09:15pm
On 7th Apr, 2011 apbellamy said:
what do you mean by offset? There's a correction option for angle correction on the crank position sensor, just make sure you set it the correct way (positive or negative). Mike knows all about that
It's in the options somewhere. I tried messing about with this but it would not change the offset, so in the end had to adjust all the values in the table by 4 degrees which is a bastard as i've now moved the bracket to get better clearence for the fan belt. On 7th Oct, 2010 5haneJ said:
8th Apr, 2011 at 07:16:23pm
Yeah this is my problem. but im having trouble working out how far out it is. im guessing its 3 degrees out but i dont know wether to + it to all the values or - it... When it should be 0 its reading 6 on the gun or when the gun is 0 its reading 3 on the crank.... (normal timing gun so reads double). right so do i add 3 to all my values or -3 from all my values? And yeah when i say offset i meant correction for if you have the sensor a few degrees out. Cheers Johnny. |
