| Home > Help Needed / General Tech Chat > 101?C | |||||||
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
22nd Jan, 2005 at 07:04:13pm
If they dont want to know i'd suggest you mention that they are obviously unfit for the purpose they were sold for and that if they don't exchange them you will have to consider reclaiming the cost of them in the small claims court. May be worth writing it in a letter, but try them on the phone first. I usually try to speak to someone in authority when i have trouble.
22nd Jan, 2005 at 07:06:07pm
Forgot to say. Not to sure how you stand on your wheel. It may be worth asking for a discount on the calipers to balance this up.
23rd Jan, 2005 at 12:36:29pm
i used it on friday, but then i noticed the fluid everwhere.
24th Jan, 2005 at 01:14:27pm
Nic, I've got some new minispares calipers to fit, hope mine are ok, I have had two sets in the past but had no problems. do you know where they were leaking from, they may just need nipping up.
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
24th Jan, 2005 at 05:42:12pm
i've got the minispares calipers too, when i bought the car it was running solid discs, i bought the spacer kit and capscrews holding the caliper together were really tight, 1 of them had locked up and nothing would shift it, and i ended up getting someone at work to drill it out for me!
26th Jan, 2005 at 10:00:23am
The ones i was on about was a batch of porous castings they had. Good idea to check they are all done up tight, but i guessed you'd have allready looked at this before writing on here. |
26th Jan, 2005 at 09:03:23pm
indeed i did check they were tight! what do you think my name is feeble?? (haha sorry)
26th Jan, 2005 at 10:43:11pm
hi had a problem with the planet gears on my old minispares diff, I must say, mini spares replaced it on the spot On 15th May, 2009 TurboDave said:
46 Posts Member #: 733 Member Gatwick |
29th Oct, 2005 at 11:55:57am
Nic,
29th Oct, 2005 at 12:56:04pm
an update:
30th Oct, 2005 at 11:25:35am
you wont be disapointed |
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
30th Oct, 2005 at 08:08:42pm
are u running a rcing shim in the head or r u still using the thermostat ?
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
30th Oct, 2005 at 09:30:19pm
74deg thermostat with 6 6mm holes |
