Home > Technical Chat > final drive ratio choice - ideas please gents.
EDIT: Was talking nonsence.
Edited by apbellamy on 12th Feb, 2010.
Smartass!!!
On 12th Feb, 2010 Vegard said:
On 11th Feb, 2010 robert said:
straight cut box 2.58 1st gear ..,3.2 ....helical box 2.9.
*happy* editted to make it understandable for moz *tongue*...
if you have a gearbox with the straight cut teeth ,which has a 2.58:1 ratio 1 st gear ,thats the one you use to drive off from a standstill ,then i would advise advocate and utilise a differential gear ratio of 3.2:1.
if you are using a standard unmodified helical box ,with a much lower 1st gear ,thats the one you pull away with ,then i would install,fit,emplace,a 2.95:1 ratio differential gear . *wink*
This is very true.
