| Home > Help Needed / General Tech Chat > OT Mondeo TDCi flashing glowplug light update 8/6/10 | |||||||
19th May, 2010 at 09:45:03pm
On 19th May, 2010 mini13 said:
ahhh, stoopid electrics... YES I seriously doubt it! |
19th May, 2010 at 09:50:05pm
if as Rod says it is the fly wheel sensor, how about unpluging it and seeing if there is a change?
19th May, 2010 at 09:55:04pm
Mine's 03 too, first to have the VNT rather than a wastegate but still operated by an air actuator (like a wastegate actuator).
19th May, 2010 at 09:55:22pm
On 19th May, 2010 paul wiginton said:
Right, had it on diagnosis kit and the map sensor wasnt working. Spent a fortune on one today and that aint fookin fixed it either. Its driving OK but theres no boost so I thought the map sensor would sort that. Any ideas? How do I know Im actually producing boost? Paul EDIT The light is still flashing, could it be that now I need to get the fault code removed? On 5th Sep, 2011 Vegard said:
19th May, 2010 at 10:01:15pm
It simply didnt read anything Scrufster I seriously doubt it! |
19th May, 2010 at 10:06:02pm
Wiggy please carry out tests as above and report back ta! On 5th Sep, 2011 Vegard said:
19th May, 2010 at 10:09:08pm
If it is in limp there must be a code or if the light is on also??? On 5th Sep, 2011 Vegard said:
19th May, 2010 at 10:09:20pm
Would love to mate but I dont know what the hell youre on about, I dont understand this sort of shit I seriously doubt it! |
19th May, 2010 at 10:13:53pm
19th May, 2010 at 10:19:07pm
There is a very good forum here
19th May, 2010 at 10:20:38pm
this might help fault find it...
19th May, 2010 at 10:31:58pm
19th May, 2010 at 10:46:11pm
On 19th May, 2010 Rod S said:
There is a very good forum here http://www.fordmondeo.org/forum/showforum.php?fid/164/ If I've linked it right it should take you straight to the relevant TDCi pages. Reading that forum, it seems the ECU needs resetting and needs to learn the new parts, will try that in the morning I seriously doubt it! |
25th May, 2010 at 05:26:42pm
Possibly a good development.
Edited by paul wiginton on 25th May, 2010. I seriously doubt it! |
25th May, 2010 at 05:41:40pm
Surely, he meant suck it Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
25th May, 2010 at 07:36:53pm
usually if its the AFM, disconecting makes it drive much better! (as the default guestimated map is better than the duff AFM)..
25th May, 2010 at 07:38:28pm
next time you get it diagnosed could you post up the actual codes in the format P**** :) turbo 16v k-series 11.9@118.9 :)
25th May, 2010 at 09:27:05pm
The airflow sensor can indeed be tested by blowing on it but if you have a multimeter on the signal wire you should see the voltage change as the resistance changes with temperature - it should increase as the wire is cooled by blowing and reduce as the wire heats up again. On 5th Sep, 2011 Vegard said:
25th May, 2010 at 09:31:41pm
If it is in limp mode you may find the afm is not reacting as it should anyway. Start with the map sensor problems and check you have an earth, 5v reference supply and a signal going away by backprobing the plug into the map sensor. You cannot output the codes on these cars by the blink code method like some vauxhalls so FGS get a scanner on it! On 5th Sep, 2011 Vegard said:
![]() 136 Posts Member #: 5193 Advanced Member Dunstable |
25th May, 2010 at 11:43:14pm
the offer is still their of being able to use autologic to see what is going on will bring you up the errors |
26th May, 2010 at 06:13:09am
On 25th May, 2010 munnracing said:
the offer is still their of being able to use autologic to see what is going on will bring you up the errors Forgot about that offer mate, when can you fit me in? I seriously doubt it! |
26th May, 2010 at 05:03:19pm
Just drove it home with the airflow sensor disconnected, its not back as it was but it certainly was more responsive. Maybe it is that I seriously doubt it! |
8th Jun, 2010 at 05:15:02pm
Finally found someone who can read the codes, nobody can do anything pre obd2 it seems. I have 1 code P2336 - cylinder 1 is beyond knock threshold I seriously doubt it! |
49 Posts Member #: 768 Member Fixing my car.... |
8th Jun, 2010 at 05:44:39pm
That would suggest a faulty injector, most likely to be leaking |
8th Jun, 2010 at 08:45:24pm
or injector coding.. turbo 16v k-series 11.9@118.9 :)
