Home > Help Needed / General Tech Chat > fuel pressure test has thrown up some weird results
any better on the way home ben ?
Bman
Member #: 5647
swindon wiltshire
much better..i was just about to send you a mesage..it seems to pull so much stronger now than it did..i still have the boost wound all the way down but it has definatley helped... i think ill order a new decent coil tonight...do you have any recommendations ?
i use a bosch red coil on the tvr ,seems to work well . but make sure its right fir the type of dizzy you have. eg points or electronic .
Bman
Member #: 5647
swindon wiltshire
its electronic as far as i know ...ill have a quick hunt on the internet and see what i find
my problem so far is that ive got 4 electrical connections on my coil and most ive found only have 2 ??
http://cgi.ebay.co.uk/GCL143-LLB198-LUCAS-...=item48384aa179
Edited by Bman on 10th Apr, 2010.
