| Home > Help Needed / General Tech Chat > turbo-technics | |||||||
74 Posts Member #: 11056 Advanced Member South yorkshire |
16th Jul, 2015 at 06:14:57am
That's fair enough about the dyno! And I'm thinking off modding it abit and running it like a normal set up with a intercooler, all Id have to do is take the carb off the turbo, put a extension pipe onto the inlet manifold and run it to the side, surely that will run better and air cooler! |
16th Jul, 2015 at 06:57:58am
...That's what I was trying to get at in my previous post. If you try to get an intercooler in there it will run like a dog with 3 legs. Fuel will drop out of susspension and mixture will be all over the place by the time it reaches the inlet.
Edited by PhilR on 16th Jul, 2015. |
16th Jul, 2015 at 07:14:59am
Will do Phil cheers! I'm gonna put it back to a standard setup, because as it is its a suck through system, dragging the fuel through the turbo, so I'm gonna change it so it goes straight from carb to inlet manifold, and Ye I will get a "show us yours" on the go! |
![]() 428 Posts Member #: 10128 Senior Member Dorset |
16th Jul, 2015 at 07:23:34am
Seems a shame to cannibalise a rare setup to make an 'ordinary' one, but hey, good luck! |
16th Jul, 2015 at 07:30:18am
So run BOTH carb and intercooler post turbo?... Got ya.
16th Jul, 2015 at 07:30:20am
Yer it will be easy to put back to normal, just out the carb back onto turbo and take pipe off inlet manifold |
16th Jul, 2015 at 07:32:20am
Hmm I'm still undecided, if that is true about him producing 151bhp through that setup then I might just go for that, sure that will be fairly quick! |
16th Jul, 2015 at 09:53:40am
The 151 bananas atw is clearly wrong. Many people on here don't have that and have very well though-out cars. I'd be interested to see the printout.
16th Jul, 2015 at 12:49:43pm
Yes mate I'm gonna stick with it, not gonna change because as someone said further up it is quite a rare setup so I'll just see what it runs when it's on, and I don't no how to attach photos or id upload it! 😂 |
16th Jul, 2015 at 01:00:49pm
I agree, I'd just run it as it comes. It may surprise you. Mike's mini was pretty quick when he (briefly) ran suck through, I struggled to keep up with it in my A3. If something is worth doing, it's worth doing half of. |
16th Jul, 2015 at 01:01:40pm
What's your a3 running? Hahaha |
16th Jul, 2015 at 01:07:38pm
It was only a 140nana Diesel but Mike wasn't running much boost at all. If something is worth doing, it's worth doing half of. |
16th Jul, 2015 at 01:44:15pm
Should be a relatively easy build. See what it drives like ang don't worry about rolling road claims. If you want more later, you'll already have an engine that's ready for boost so a good chance you won't have to pull the engine out, just collect the right bits and swap them over.
16th Jul, 2015 at 05:44:43pm
Ye that's sound, thanks for all your help anyway! Can't wait to get it together now! |
24th Jul, 2015 at 08:23:33am
Righty, this is what I've found in the car...
81 Posts Member #: 11403 Advanced Member |
28th Jun, 2016 at 10:02:13am
Did you manage to get this fitted? I just got one new and wondered if I should fit it to my 998 |
