| Home > Help Needed / General Tech Chat > Metro radiator fan switch | |||||||
21st May, 2010 at 05:45:37pm
I use a sensor that just pushes between the gills of the rad in the position you choose and it works for me -worth considering ?. |
21st May, 2010 at 05:50:43pm
I'd still need to seal the hole and the whole mounting position for whatever I used to seal it still sticks out backward into the alternator.
520 Posts Member #: 2093 Post Whore Grenoble, France |
21st May, 2010 at 11:28:58pm
I've had some trouble to setup the rad switch. Since I've bolted a water cooled turbo the engine heats much faster, I had to limit to the minimum the flow through the turbo and the bypass (I should have blocked it) in order to make water flow through the rad.
Edited by alpa on 21st May, 2010. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
3 Posts Member #: 9121 Junior Member |
14th Oct, 2010 at 06:27:17am
On 21st May, 2010 Rod S said:
Mk1 so inlet/outlet at same end but which is which ??? The fan switch goes into one half of the header but should the radiator be orientated so the switch is at the bottom (where it would point forwards) so be measuring the return temperature, or flip the radiator the other way so it's in the top (pointing backwards) and measuring inlet temperature. The radiator is 100% symettrical in all respects apart from the fan switch so I can't work it out........ you're absolutely right. the radiator thing really are usable in all aspect. cause this car part help in exhausting the heat to avoid over heating of the engine. nuriko travelling a hundred miles starts at a single step Edited by nuriko on 5th Mar, 2013. |
4 Posts Member #: 9122 Junior Member |
14th Oct, 2010 at 06:30:29am
wow! this community really helps me alot! i enjoy reading and gain info.
someday everybody will understand me and appreciate my car. |
