Home > Help Needed / General Tech Chat > Piston Dump Valve.....All I get is chatter
On 26th May, 2010 mini13 said:
*happy**happy**happy*
On 26th May, 2010 theoneeyedlizard said:
Mine had swollen and split in 3 places.
Are we back to talking about banjos?
haimesyboi
Member #: 5702
Cornwall
strip and clean it, check the o rings for swelling and whack it back together with a smear of vaseline *wink*
i think it is supposed to be open at idle.
hammoj28turbo
Member #: 1502
Aberdeenshire, scotland.
Yeah,
It seems to dump but only after the chatter which makes me think its sticking.
At idle, the main piston slides open and the small nylon one stays shut. Rev it up and it all opens up.
WOndering if its maybe loosening up.
Il try some vaseline on it tommorro and see how that goes.
Johnny
Member #: 6926
Accrington
yeah mine did the same... i used wd40... (dont use wd40 lol) but it worked! just get something lubricative on it! and it should definately work
hammoj28turbo
Member #: 1502
Cool,
Do you reckon the fact that the turbo chatters then the dump valve comes in late is just due to it sticking?
On 27th May, 2010 hammoj28turbo said:
Cool,
or the pipe from the manifold is mahoosive, too long and too large bore gives the same result
more likely to be the sticky valve though
hammoj28turbo
Member #: 1502
Lol, cool. Il try lubing it up then.*happy*
haimesyboi
Member #: 5702
Cornwall
I think the twin piston ones are supposed to be for injection cars so one piston stays closed at idle to avoid messing up the air metering.
one of the pistons cold be stuck shut, what vac pipe are you using? check it is not collapsing.
hammoj28turbo
Member #: 1502
Im just using silicone vac pipe....
Just stuck a brand new diaphram dump valve on. Didnt make any difference. Still chatters.
Any ideas?
t3gav
Member #: 229
Gavin@minispares.com
kent
Silly question but you did you take the blanking screw out of the manifold take off?
hammoj28turbo
Member #: 1502
Yeah, the srews removed. I did have to go check tho.lol
Edited by hammoj28turbo on 28th May, 2010.
hammoj28turbo
Member #: 1502
Heres my setup. Im stumped.lol
hammoj28turbo
Member #: 1502
Just a thought,
At idle with the piston dump valve, My boost gauge rev on the - scale.
With the new duaphragm dump valve which is closed at idle my boost gauge is sitting at 0. Like its not getting a reading....wonder if that port is blocked somehow....
hammoj28turbo
Member #: 1502
Should there be resistance when you blow through the vacuum take off spacer?
I cnt poke anything down it? But if I blow through it I have to really blow hard.
Is it a straight through pipe or does it branch off?
hammoj28turbo
Member #: 1502
Had a look at the vacuum spacer and there is a hole in it but its tiny. Is that maybe my problem?
I dont even get a reading on my boost gauge now with this new dump valve on.
Johnny
Member #: 6926
Accrington
if the hole is tiny then YES, if the holes in that T piece are small then yes it wont work... i have a t piece on mine but the t piece has 2 large holes and 1 small (the small one is sent to the gauge and the other 2 to the manifold and the Dump Valve... make sure the hole in that spacer is at least 3mm? take it off and drill it
hammoj28turbo
Member #: 1502
Hmmm, the whole in the take off is hardly 1mm id say.
Also, the dump valve is faulty. You can blow into the top of the vacuum bit on it and it comes out so its not sealing. Waiting on a replacement.
hammoj28turbo
Member #: 1502
Got the piston dump valve working!!!!
Turn out the hole in the spacer plate was too small.
I took the brass fitting out and drilled it through so it was straight through.
Slapped it all back on and Ptshhhhh. No chatter anymore. Hehe, awesome.*happy*
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Good work! Top marks for posting good quality pics rather than the blurry ones people tend to post too!
On 7th Nov, 2008 Nic said:
naeJ
m
Johnny
Member #: 6926
Accrington
nice!
