| Home > Technical Chat > Opinions needed on this piston damage | |||||||
3rd Jun, 2010 at 08:03:27pm
its not the cooling of No4 cylinder that is the problem, its cooling the chamber, and where the A series 5 port head problem lies, hence the theory of using the heater take off to aid flow around No4 chamber.
3rd Jun, 2010 at 09:46:12pm
I suppose it isn't beyond the realms of possibility that the fuelling, ignition and cooling are just ok for 1, 2 and 3, but the extra temperature around no 4 just takes that cylinder over the edge.
3rd Jun, 2010 at 10:03:11pm
This is the map I started with, which was taken from on here somewhere, and I have modified the off boost areas with the use of some det cans. It is an amalgamation of a NASP curve off boost and the standard turbo curve when on boost. What are peoples thoughts on this map? Is it a safe map to go back to?
3rd Jun, 2010 at 10:08:25pm
To me that looks like a megasafe map. If something is worth doing, it's worth doing half of. |
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
3rd Jun, 2010 at 10:14:46pm
Yes that looks very safe to me. Do you have a wideband fitted ? |
3rd Jun, 2010 at 10:18:48pm
I have a wideband ready to go on when the engine goes back in. |
3rd Jun, 2010 at 10:25:44pm
Lean mixture is my bet looking at that map. I've got a 24deg map on the van and it doesn't seem to pink. If something is worth doing, it's worth doing half of. |
4th Jun, 2010 at 09:33:47am
